2 inch lift on a 1/2 with coils, got pixs
did a 2 inch with alluminum spring seats on the front and 2 inches of plate on the frame side on the rear. I have found that the upper ball joints and shocks are near the limit and the rear shocks are almost fully exended
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Does it ride any different?
Strongman Garage
![]() Join Date: Apr 2000
hmmmm sounds intresting, so basicly you put some flat steel between the coils and frame in the rear? how did you secure it? id like some details......... thanks
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
The plate needed longer bolts, works fine. As for the ride, ya it seems to be a bit smoother, maybe due to the higher center of grav.
lift
with your upper A-arm near ther limit you can use the AIM industries of fab-tech upper control arm for the 73-up 2-wd lift kits. both of them are slightly longer and have a bend in them to gain more clearance and downward travel. the ball joint angle is also adjusted to not bind in the in the lifted position.
Jim Davisburg, MI 69 Camaro SS LT-1/6-spd 71 C-20custom deluxe burb 402/400 (gonna get back to it) 72 C-10base burb 350/3-spd 79-VW Scirocco GT-3 race car 2.0L/5-spd 02 chevy suburban LT Supercharged dropped on 22's |
I've seen those, there about $300 a set and you need to convert to 73 and up control arm shafts
If you can weld, you can modify you stamped uppers.cut them at the ball joint mount offset them and box the offset.
I tried that yrs ago when I didn't know any better. The arm became brittle and cracked. I'll go with the aftermarket arms later on.
