06-14-2005, 02:14 PM | #1 |
Life is a gamble
Rivet removal
I'm trying to install a sway bar, but to do that, I have to remove two rivets. I've started on the first. Its on the driver's side. I have ground off the top of it with a grinder. I've been using a punch and hammer to push the rivet through. So far I've only moved it about a 1/16th. I've sprayed it with PB Blaster several times. Any suggestions?
I know that many of you on the board have done this mod. I figure someone can give me some advice. Thanks
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
06-14-2005, 02:15 PM | #2 |
I ran into the same problem. I ended up drilling them out after flattening the tops with the grinder. Beware of hot shards of metal!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
06-14-2005, 02:17 PM | #3 |
Pretty much need an air chisel. The best way is to knock off the head with a chisel and then switch to a punch and drive it through if the air chisel isn't quite powerful enough to take the head off drill it with the biggest bit you have first and it'll make it easier. You can probably blow em through with a plasma as well.
Saskatoon, Saskatchewan Canada |
06-14-2005, 04:43 PM | #4 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
06-14-2005, 03:32 PM | #5 |
Its Magically Delicious
put the front end on ramps and get yourself a bigger hammer ... it'll come
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-14-2005, 03:33 PM | #6 |
I drilled mine out, make sure your drill bits are SHARP and I left my cordless drill in the case and used my elec. drill. As mentioned watch out for hot pieces of metal and protect them eyes. Doug
06-14-2005, 03:41 PM | #7 |
Air chisel -old rivet gun will do in a jiffy. I have an old air craft factory rivet gun that I use. They ricochet like bullets. Be carefull. "Goggles"
06-14-2005, 05:19 PM | #8 |
Junk Chevy C20 Big Block
heat!
06-14-2005, 05:46 PM | #9 |
Keepin an eye out
If you keep hitting it it will come out.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
06-15-2005, 09:38 AM | #10 |
More Cowbell....
A wise man once said....
"Just keep beating on it.....it HAS to come sooner or later" ...but he was naked when he said it, so....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
