06-14-2005, 06:29 PM | #1 |
Dwell setting???
What's the best way to set the dwell in the points when you don't have a dwell meter? Can you adjust it while its running and listen for anything? Thanks for any help.
Joshua |
06-14-2005, 06:36 PM | #2 |
Years ago, and I mean many years ago, I used to adjust the point gap with a piece of matchbook cover. That was before I was able to buy a dwell meter. That always worked for me.
1997 GMC Sierra Ext 1965 Mustang |
06-14-2005, 07:11 PM | #3 |
with the cap off bump the motor over to get it so the points ramp is on the highest point ov the dizzy cam and use a feeler gauge to set the points at .019" if they're new p[oints or .016"gap if the points are used
06-15-2005, 07:06 PM | #4 | |
Out draggin'
Exactly... The matchbook method works in a pinch too
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
06-15-2005, 07:28 PM | #5 |
Saving 1 truck at a time!
Don't forget to reset your timing after setting the dwell since it affects the timing. I know you probably already know this but just thought I would mention it.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-15-2005, 06:10 AM | #6 | |
1968 Chevy 4x4 307 4 speed |
06-15-2005, 08:38 PM | #7 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-15-2005, 08:32 PM | #8 | |
member #16
Another method that has been around for years, is to adjust while running you turn the adj. screw in until it starts to misfire and then back it out 1/2 turn. You can check with dwell meter and it will be about 30 degrees dwell. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
