06-14-2005, 06:56 PM | #1 |
NP205 oil seals are hard to locate???
One of the 2 rubber seals that goes inside the adapter between the TH350 tranny and NP205 in my truck has gone bad, and oil and trans fluid are sloshing back and forth.
To my surprise, the local GM dealer in my area can not seem to locate the seals. In fact, they can't even cross reference them to find out which ones to order. There are little numbers on the seals and everything, and the guys behind the counter still can't figure it out. Anybody know where to buy these seals? Or what the new GM parts number is? Thanks
1969 K5 Blazer CST Always waiting for the Puget Sound sun..... |
06-14-2005, 09:22 PM | #2 |
go to your local bearing supply place. they can supply them.
Phuloi68 Indy survivor Norwood survivor Big Sandy survivor for those who fight for it...
F R E E D O M has a price the protected will never know. |
06-14-2005, 11:40 PM | #3 |
Tony "Life is a Team Sport" To the memory of the Hendrick Motorsports Plane Crash Victims |
06-14-2005, 11:41 PM | #4 |
I have the part numbers at work, hope I remember tomorrow.
06-14-2005, 11:49 PM | #5 |
We can ge them over here in Spokane...
Support The Board |
06-15-2005, 05:15 AM | #6 |
Yup, a bearing sales store will just pull or cross the p/ns on your seals.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-16-2005, 02:08 AM | #7 |
Make sure to check and probably replace the o-ring on the t-case input shaft. I have had two 350/205 setups that leaked from that seal not the ones directly in the adapter.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-17-2005, 08:48 AM | #8 |
tell your dealer to look in group 4.515. the part number 3979626 should be the seal that you require, but check your application with your dealer, Be sure and use a GM seal as I've not had good luck with aftermarket seals. The part number shows to fit just about everything GM makes that had a NP205.
06-27-2005, 12:22 PM | #9 | |
Crazy
77 SB Stepside in a bunch of pieces scattered around the garage. |
06-21-2005, 08:42 AM | #10 |
Eric 1969 K20, 465/205 package Last edited by HeavyK20; 06-21-2005 at 08:43 AM. |
06-21-2005, 12:39 PM | #11 |
1968 C20 Vortec Beast
Do I see that another GM parts spec. is a member here? That's what I do.
06-21-2005, 12:56 PM | #12 |
stueber68, how long have you been at it?
