Old 06-15-2005, 02:41 PM   #1
Tim240Z
Tim240Z's Avatar
Bug deflectors for our trucks
I remember seeing a post on this topic a while back, but I cannot see it now...been back about 10 pages....maybe I passed over it?
Are there any vendors that make a buf shield for our trucks? I have a nice new hood and fresh paint...my old one was littered with stone chips along the front verticle surface.
If not, I have my old hood still for a template, I can buy some lexan and make one......
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 06-15-2005, 02:52 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Tim, that sounds pretty cool. The Lexan thing. Could you elaborate?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-15-2005, 04:53 PM   #3
Tim240Z
Tim240Z's Avatar
Well, I figured I would take a 4-5" strip of lexan, long enough to stretch from one end of the hood to the other (fender to fender iow), then used a heat gun to slowly heat the lexan and let it 'sag' into shape around the front of the hood. Then make a mounting bracket (I'm thinking that a strip of steel "U" channel will do, then glue, bolt or clamp the lexan into it).
Lexan can be painted on the hood side, so that from the front, it would look nice and smooth.....just thinking out loud.....
Bunch of work if one could just be purchased....
1972 Suburban C20
Old 06-15-2005, 05:24 PM   #4
chickenwing
Don;t know of a molded bug gaurd for or trucks. Have looked. Considering that 3M plastic film stuff. Apply and cut to fit. I'm just scared I'll ham it up and cut into the paint.
Old 06-15-2005, 05:28 PM   #5
Tim240Z
Tim240Z's Avatar
Yeah, I looked into that too and have the same fears. Plus, I can't really see it standing up to a stone....the film will get tattered and look really bad.....
Guess I am off to the plastics shop.........
1972 Suburban C20
Old 06-15-2005, 05:51 PM   #6
COBRO
Active Member
Thumbs up
LMC does sell a molded bug shield for our trucks but its held on by double sided tape to the front of the hood - there was a posting about them awhile back and everyone wondered how long they would stay on - I ordered one three or four yrs.ago and have never installed it - allways been waiting for the new paint job and still waiting!!!!!! HTH:::::::CB
COBRO is offline   Reply With Quote
Old 06-15-2005, 05:47 PM   #7
chickenwing
Dunno about that.... I've saw it installed and it is fairly rubberized in texture. Should be good for a few intermittant small rocks/gravels. Definate yes for the bugs. Supposed to let uv pass through also so the paint fades at the same rate.
Old 06-15-2005, 06:30 PM   #8
chickenwing
I'll be darned. There it is on page 88 of my catalog. Looks like it is still 2 sided tape for the install...
Old 06-16-2005, 07:20 AM   #9
4x4Poet
My concern is whether the hood will always pop up high enough to get my fingers under the hood with the shield installed to pull the hood up the rest of the way. The shield must take up the precious little space between the outer grill and the hood edge. I also don't believe LMC's shield has a wide enough opening to let cleaning be done. Maybe enough for a high spray. Just wondering.
I think I'll go with professionally applied 3M plastic on my upcoming K10's repaint. That way I don't have to worry about messing up the cut or placement. It's pretty tough stuff and can be removed (professionally) and replaced if a rock goes thru. I think they just use a heat gun to loosen the adhesive. Do any touch up paint between the R&R.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
