Old 06-16-2005, 02:03 PM   #1
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Drop Spindels
Do I need drop spindels on my truck if I am going to lower it. I plan to put on air bags to drop really low and be able to bring it back up when I need to.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 06-16-2005, 02:27 PM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
Depends on how low you want to go. You don't need them to install air bags but they'll get you 2.5" closer to the ground.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-16-2005, 02:31 PM   #3
tomatocity
tomatocity's Avatar
drop spindles give you 2.5" of lowering more than coil spring or airbag lowering. Theoretical: Say you lowered the front of your truck 5" with coil springs or airbags. Then if you install the drop spindles you will have lowered your front end a total of 7.5".
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-16-2005, 06:07 PM   #4
diggertodd
diggertodd
diggertodd's Avatar
spindles with bags is better
Simple theory... By using drop spindles with air bags, its not just a matter of "how low you can go" but also the volume of air you have in your bags at driving height. To achieve the same height without drop spindles is to have much less bag-air volume. Lets say you have 2 1/2 drop spindles with your bage, then you 2 1/2" of extra air (and suspension movement) in you bags at the same actual ride height.
or just tell me i am
diggertodd is offline   Reply With Quote
Old 06-16-2005, 07:58 PM   #5
FirstGen
Just Don't Stop!
FirstGen's Avatar
your right on the money!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
