06-16-2005, 10:27 PM | #1 |
Wiring harness
What is the best complete wiring harness kit? Why? Where is the least expensive place to purchase one from? I have a 65 GMC and I was also wondering if I ordered one for a chevy, would it work with everything if i bought a chevy dash gauge set?
65 SWB 454 350T |
06-17-2005, 01:10 AM | #2 |
wiring harness
i actually saw one on e-bay yesterday for $370. i think??? at "Buy it now" price. that was from american autowire. they claim to have the most complete kits, even better than painless. the kits come with everything, but i don't know about the gmc thing. i'm sure it would probably work, or they make the right one for you.
06-17-2005, 02:12 AM | #3 |
YES_____NO
american auto wire
Part #500560 $449.00 The Classic Update Series wiring kit, designed specifically for the 1960-1966 Chevy and GMC "second series "trucks. Built with the same foresight and engineering as all of our popular Classic Update Series kits, this kit accommodates all the popular accessories available to bring your truck 's electrical system up to date. We have engineered a kit that easily interfaces with after market accessories as well as reproduced original tail light, headlight, and running light assemblies. In keeping with the design of the "Classic Update Series "kits, there is still complete flexibility in engine compartment and body wire routing for the custom touch. As with every Classic Update Series kit, only the best components and detailed installation instructions are utilized in building the most complete kit offered. Features of this kit include: Original dome lighting is included in the wiring system. Additionally the Classic Update Kit includes under dash lighting and enough spare circuits to add power door locks, power windows and much more The 18 fuse, 21 circuit fuse box comes completely ready to install under the dash The harness was manufactured to accommodate the factory dash supports while not interfereing with any aftermarket equipment that you install under the dash now, or in the future Factory replacement items such as the original light harness grommets, headlight and park light connectors are also included. (This makes installation easy since you don't have to save and reuse old parts) All of the Classic Update Kits come ready to connect to the updated alternator and original coil/distributor or most aftermarket systems without the needs for additional parts Original design rear body weatherproof boot and tube assemblies and original design light sockets make attachement to the original or reproduction tail light assemblies as easy plug-in. The dash cluster disconnect system, unique to American Autowire, is included in every complete kit. Using low insertion force connectors means that assembly and disassembly just became significantly less time consuming and cumbersome. The fuse box and custom mounting plate are designed for bolt-in under dash installation All required hardware is supplied Instrument cluster wiring is designed with a "cluster harness disconnect" system for easy service and assembly All original terminals, connectors, and light sockets are also supplied for original cluster gauges Steering column connectors will plug directly into most aftermarket steering columns as well as 1969 and later GM columns which utilize stock GM turn signal switches The original column can also be wired by using the supplied mating connector and terminals Under dash light sockets, door jamb switches, new ignition switch, replacement headlight switch with internal circuits breaker, retention collar nut, adjustable length shaft, and custom knob are also included! Engine wiring includes connectors for points type and HEI distributors Power & Tach connectors are supplied for GM HEI distributors. Alternator connectors are supplied for GM"SI" series internal regulator alternators The rear body harness assembly is designed to plug into the main harness in the original utilizing existing retainers Flexibility in harness design allows for original or custom routing
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
06-17-2005, 11:07 AM | #4 |
ya what mongo said lol!!!!! like i said theat deffinately sounds like the best kit to me.
06-17-2005, 11:17 AM | #5 |
YES_____NO
Yes they are great systems. Seems spendy, but for all the stuff you get you cant beat the price.
06-17-2005, 03:49 PM | #6 |
Thanks for the info, I will call them today. Anybody have any ideas on the GMC issue? I want to change to the Chevy for more instrument panel options but I guess I would lose the connections to two of my four front lights? Right?
65 SWB 454 350T |
06-17-2005, 03:58 PM | #7 | |
YES_____NO
If I am not mistaken I think each of you head lights has only two prongs on them as where the trucks with only two head lights has three. 1. ground 2.low 3. high. you may be able to modify and make your own connections.
