06-18-2005, 09:32 PM | #1 |
what do you use for a security system?
what do you use for a security system on your chevy? Im looking for one for my 67 swb. thanks
06-18-2005, 09:44 PM | #2 |
20' Daredevil (Ret)
I remove the keys, which is more than I used to do. Seriously. I'm glad I live in a low-crime area.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-18-2005, 10:41 PM | #3 |
Where's my beer?
Headers and turbo mufflers. I also live in a low crime area, and I guarantee I'd be out of bed so fast if someone tried to get the truck. Besides It's so ugly why anyone would want it is beyond me.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
06-18-2005, 10:51 PM | #4 |
Keep On Truckin'
About the only thing that's hard to thwart is towing, unless it is chained to the ground.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
06-18-2005, 11:16 PM | #5 | |
06-19-2005, 12:36 AM | #6 |
Got Big Block?
I'm going to try one of those Hornet hood locks in conjunction to the hidden kill switch hooked to my MSD box.
"Experience is what you get when you didn't get what you wanted." |
06-19-2005, 07:10 AM | #7 |
YES_____NO
Best security system there is
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
06-19-2005, 07:29 AM | #8 |
This is a neat little fake alarm that was posted on here awhile back........
http://67-72chevytrucks.com/vboard/s....php3?t=141268
1997 GMC Sierra Ext 1965 Mustang |
06-19-2005, 09:09 AM | #9 |
Orange Truck
A body shop guy that did my paint and body work suggested removing one wire on the distributor and putting in the cut filter from a cigarette end and then replacing. If someone tries to steal, the truck will not start. Just be careful that you are not under observation when doing this. I have also looked at the battery "key" disconnects. Hope this helps.
06-19-2005, 10:48 AM | #10 | |
A TOGGLE SWITCH INLINE IN THE PURPLE WIRE OF YOUR NUETRAL SAFTY SWITCH WILL NOT ALLOW YOUR VEHICAL TO TURN THE ENGINE OVER WHEN THE SWITCH IS ENGAGED. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 06-19-2005 at 10:53 AM. |
06-19-2005, 10:59 AM | #11 |
12 GAUGE OO will just about clean what was there.
i too am thinking about that. was looking at the newer cars and trucks they have a switch that you have to plug in someting then it will start. the problem is that with that set up you can just crimp the wires and start it. but if there was a way to install something that needed a certon voltage say 2 volts to make it work then that might be good. |
06-19-2005, 12:51 PM | #12 |
Keepin an eye out
The Club..I know its not much but if someone wants your truck their gonna get it.
And todays tow trucks are something, they dont even have to get out to drag you away
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 06-19-2005 at 12:52 PM. |
06-19-2005, 02:11 PM | #13 |
Thats the Hillbilly way
i use the club to slow them down or look elsewhere , and at night disable the HEI power wire .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
06-19-2005, 09:32 AM | #14 |
i am interested in this topic too,can you install a alaram without power locks?maybe wire it to a door light switch?my truck has either yet,ive thought of disconnecting the battery and locking the hood but that would get old after awile too
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts- |
06-19-2005, 03:06 PM | #15 |
my truck had been converted to a floor shift automatic, and you have to wiggle the colum shifter to activate the neutral safety start switch, so you could play with that some. if you have a system inside, you should use screw heads that most thieves don't carry like a torx head. remove the outside hood latch and run a cable inside to open it. the flashing red light in the dash keeps some thieves away, but putting a security system sticker on your window is about 50/50 for effectiveness. you can buy a no wheel no steal kit, so everytime you go somewhere you can take the steering wheel off. you can get a radio with a detachable faceplate, put a cover over your radio so it appears you have none, and locking lugnuts stop some people from taking your rims.
06-19-2005, 04:26 PM | #16 |
I like kill switches, batt disconnects, and alarm systems (w/remote signal but w/o siren or horn hook up). However, installing a kill switch or alarm sys can all to easily prove ineffective if the hood is not also locked down. It's so easy and cheap to install brackets on the underside of the hood and on the frame rails and then run a chain or thick cable between them with a weatherproof lock on the frame.
Lock both sides to make it doubly tough to open the hood. Use the hood's inner frame for the bracket mount. Try to design the lower lock bracket so as to leave little chain or lock hoop exposure for bolt cutters. I think doing all these things eliminates 99% of thieves, so to speak. Besides tow trucks thieves, it also might not stop any thieves that just want to break some glass and steal what's inside the interior. Not too much can be done in that case unless an alarm sensor goes off and one is able to respond promply (i.e., with both barrels ).
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-19-2005, 04:43 PM | #17 |
Excelsior, You Fathead.
I have the engine on a stand in the garage and no tires and wheels on it right now. Take your truck apart every once in a while and people will be less likely to steal it.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
06-19-2005, 06:17 PM | #18 |
yea mine has no bed and no eng./tras and i have it sitting in the driveway. anybody that wants a hood could come by and take it because the hinges are off and it's just laying in place. doors are locked though, gotta do that.
06-19-2005, 06:42 PM | #19 |
I use a locked garage to protect my truck.
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible |
06-20-2005, 12:21 PM | #20 |
I have a little red led light that blinks that is powered by 2 aa batteries. I just set it on the dash. looks like a alarm at night anyway! LOL actually when I see a old beater car with a alarm I wonder what is in the car people would want. but most of the time I think they are must have
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400. |
06-20-2005, 02:40 PM | #21 |
Nothings as cool as my 72
My truck is in about 200 pieces right now so im not to worried. Even if you live in a low crime area you still have to do something to prevent theft. We live on an acherage outside the city and we thought that we would never have to worry about theives until we got robbed. An easy way to prevent theft is to pull the spark plug fires off or even the plugs at night and put them back in next time go drive the vehicle.The red blinking light is good for idiot thiefs. If your worried about getting your stero stollen don't have one or get a cheap one. Using uncommon screws won't work most of the time because some guys just use a crobar to pry it out. You could probably put a hidden switch on the ignition switch up underneith the dash.
My $0.02
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
06-20-2005, 02:54 PM | #22 |
Still Green but learning
I only worry when I am out of town, and then I put it in the garage where the grocery getter was. If someone gets while I am paying for gas or something, so be it. When I have gone out of town, I pull the main plug from the dist. to the coil, then lay it back in place but not fully connected. that way everything looks right under there but isnt. My thinking is if I remove it all together they will just use a plug wire.
Again, Low crime area and if we are gone long enough to give someone time to think about it I put it in the garage.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was Last edited by phlegm; 06-20-2005 at 02:54 PM. |
06-20-2005, 04:23 PM | #23 |
Mine is not currently running and is stowed away in a pole barn behind a New Holland loader. I live in a low crime area, and I've always got my Benelli and my German Shepherd that doesn't like strangers.
67 C10 LWB Stepside- 250cid 6, 3speed |
06-21-2005, 03:51 PM | #24 |
250 V-6 Club
My 70 c/10 is on 4 jack stands right now.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523 Never ask a stupid question unless you want a stupid answer . |
06-21-2005, 06:04 PM | #25 |
Hippy
