Old 06-19-2005, 09:31 PM   #1
69 air cab
what carb to use???
What carb are you guys and gals using on your 69 C10 350 engine? I need one and need some recommendations.
69 air cab is offline   Reply With Quote
Old 06-19-2005, 09:34 PM   #2
Ironhorse
Ironhorse's Avatar
On my '71 4x4 I am using a Rochester 2bbl. With a granny 4 speed and 4:11 gears I need all the help I can get in the mileage department. About 11 mpg on a good day running 55-60 mph.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-19-2005, 09:39 PM   #3
jamal
jamal's Avatar
Believe it or not the primary barrels on a 4 barrel carb are usually ( giving you don't put a monster carb on there) smaller than the two barrel carbs. As long as you dont step into it where you open the secondary barrels you will actually get better gas mileage with a 650 or so cfm.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 06-21-2005, 02:33 AM   #4
tomatocity
tomatocity's Avatar
Edelbrock 1400 or 1406 should do anything you want. Make sure you don't have any vacuum leaks before you adjust it. After that it is a piece of cake with few problems if you don't reuse any of the older parts, gaskets, or dried vacuum lines.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-21-2005, 08:23 AM   #5
67chevemall
67chevemall's Avatar
2nd the 1406!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-21-2005, 08:35 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
67 w/350/700R4/3.73 and I have an edelbrock 650cfm (I think that's the 1406?) with the electric choke. Truck fires right up and runs great with it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-21-2005, 10:27 AM   #7
GMC AMI
GMC AMI's Avatar
Both Brocks are great little carbs! Hey Redneck taking care of my birth city? LOL!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-21-2005, 11:53 AM   #8
Gramp'sGold70K20
New
Gramp'sGold70K20's Avatar
The 1406 on my 350 has been a great choice. It has been maintenance free aside from the normal upkeep you should do on a carb. I put a fuel regulator and gauge on it and set it 5 p.s.i.. My truck has never run better. Hope this helps.
Gramp'sGold70K20 is offline   Reply With Quote
Old 06-22-2005, 09:16 PM   #9
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Glad someone out there is going with the Fuel pressure regulator like I have been preaching! heheh Glad you are liking the carb. I have 3 of them various sizes on different motors and all them are great and easy starters.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-22-2005, 10:35 AM   #10
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
1406's on both mine..........don't forget a bakelite standoff between intake and carb.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 06-22-2005, 01:38 PM   #11
tomatocity
tomatocity's Avatar
Thanks for the tip on the bakelite standoff. Is this for a good seal between the manifold / carb and for heat insulation?
Old 06-22-2005, 01:29 PM   #12
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i run 600 (1406) never had any problems plus i like how easy its to change jets
dam those edlebrock girls are so cool
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-22-2005, 01:33 PM   #13
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Are Holley or Demon carbs anygood?
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 06-23-2005, 02:03 AM   #14
dion
72 Cheyenne
dion's Avatar
I've been running the 650 speed demon for about eight months now, so far a great carb with no problems at all.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 06-22-2005, 02:59 PM   #15
67chevemall
any pics of the bakelite animal? What would that be?
Old 06-22-2005, 03:13 PM   #16
tomatocity
tomatocity's Avatar
http://store.summitracing.com/defaul...h.asp&N=400065
Summit has them in stock.
Old 06-22-2005, 06:24 PM   #17
blazerparts
just a thick ( 5/8"-3/4") piece of the same stuff your dizzy cap is made of. cuts down on heat radiated from intake.
Old 06-23-2005, 10:09 AM   #18
greasemonkey
greasemonkey's Avatar
I'm running a Holley 650 double pumper, way better response than the 1406. The vacuum is also much better at idle.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-23-2005, 11:32 AM   #19
70GMC_BOB
I got a 1406 now, but got better mialage with the stock quadrajet before.
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
