06-20-2005, 03:22 PM | #1 |
Weekend Warrior
GM Cab Mounts?????? Still Available????
Can I still get GM Cab/Support mounts for a '69 2x4 ???
Anybody know the part numbers? Any Board Vendors carry them? Thanks guys.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
06-20-2005, 04:00 PM | #2 |
Yep, sure can. I'd buy 'em from this place since they cost less than buying 'em straight from the dealer:
www.gmpartsdirect.com Here's the part numbers: Upper mount 3951798 Lower mount 3953135 Rear upper 6262170 Lower 4x4 and 3/4 ton 3953139
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-20-2005 at 04:09 PM. |
06-20-2005, 05:46 PM | #3 | |
Weekend Warrior
Problem is that I have new mounts in the truck already but they are poly's from Energy and i had to shim the front of the cab up about 1/2" to get the fender to line up with the door - and I know I put them in right cause i checked and doubled check before i put them in. I just don't liek having shims in there and the fender to door gap was fine before i pulled the truck apart so i'm assuming that the mounts are the problem Upper mount: 3951798 does this do both the core support and the front cab uppers. and then Rear Upper: 6262170 just does the Rear Uppers. So I would need: 3951798 x4 6262170 x2 3953135 x6 ????????????????????????????? gmpartsdirect doesn't have descriptions for the part numbers so i didn't know about the uppers being different for the "core/front cab" and then "rear cab" it says about $91.45 with shipping from them and if you add it up by the list prices it comes out to $126.76 Thier Prices add up to $73.92 so shipping would be $17.53 which seems a little on the high side but still better than list i guess. maybe i can get one of my local body shops to order me them for thier cost
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 06-20-2005 at 05:50 PM. |
06-20-2005, 04:41 PM | #4 |
Nothings as cool as my 72
I got mine from Scott's Super Trucks in Penhold, Ab. Can't you buy every part for these trucks except for a complete cab.
http://www.scottssupertrucks.com/ The prices on the site are in Canadian dollars for those of us in Canada.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
06-20-2005, 05:54 PM | #5 |
Try energy suspensions:
energysuspensions.com Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-20-2005, 06:42 PM | #6 | |
Where's my beer?
Did you try running those part numbers at your local dealer? just don't tell'em for what year truck they' are, because if you do they'll say "oh no got nothing for those trucks"
Paul How do you make the invisible, visible?.........You take it away. |
06-20-2005, 06:45 PM | #7 |
Sorry, missed Energy Suspension part. I just ordered a set for my 69 burb, hope I don't run into the same problem.
Rob
06-20-2005, 07:33 PM | #8 |
Those are for the cab mounts only, not sure if they'll fit under the core support.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
06-20-2005, 07:37 PM | #9 |
I don`t think it`s the mounts.Unless there`s something about your truck that it needs more flex in the mount to line-up.Is it going back together with all the same parts,I take it?
06-21-2005, 09:21 AM | #10 | |
Weekend Warrior
I put a new Radiator Support in the truck aftermarket "Goodmark/Tri-Plus" and the only thing that i can think is that they spot welded the core support mounting pads lower than original which would raise the the front of the fenders up giving me the gap that I had. when i jacked the front of the cab up about 1/2" it straightened out. (the fender gaps were fine with the old dry-rotted mounts). I used factory Doors/Cab/Front Fenders that were all original to the truck. I only changed 1 cab support (Left Front - but that doesn't effect the mounting area as the body mounts are under the cross piece that goes from the firewall to the back of the cab and not the floor supports. I just hate knowing that there is 1/2" worth of shims under the front cab mounts. I only bought the energy's cause you could get them in a whole kit and for a little less $$$$ I'm kinda frustrated now if it isn't the mounts cause i didn't change anything other than the core support
06-21-2005, 06:56 PM | #11 |
Weekend Warrior
any other suggestions to think about? to solve this issue?
06-21-2005, 07:40 PM | #12 |
Can you check that new core support against another one?Did you scrap yours?If the old cushions were real squished,maybe the sheetmetal settled with it and got a little tweaked?I don`t know,there isn`t that much to them.I know it all fit before.But,could it be in the frame horns?Just guessing around.I wish I could help you .
06-21-2005, 11:10 PM | #13 |
Weekend Warrior
yeh the original support is long gone went to the crusher in a junk car many months ago.
so i can't really compare it. The only think i thought was to try the GM mounts to see if that helps. Thanks Guys
06-22-2005, 01:40 AM | #14 |
Life is a gamble
I ordered mine from Year One because they were offering a 10% discount. They said that it came with all hardware, but it didn't. If I had to do it all over again, I would order from a board vendor.
Oh well, live and learn.
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
