Old 06-22-2005, 09:15 PM   #1
Nima
Blue 67
Why do you ...
drop the rear more than front?
Hi;
When I read different thread most of the time (if not all), I see that rear always dropped at least 1" mroe than front. I personally like the stock stance but if there is any advantage to this, I don't mind to change the rear coil to 1" drop since I am gona change the coils all around very soon.
Thanks.
Nima is offline   Reply With Quote
Old 06-22-2005, 09:24 PM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
You drop the rear 1" - 2" more than the front because these trucks have a little bit of a "rake" style stance to them from the factory. The rear is just higher than the front, and most people (not all) want a "level" stance when they lower their truck.......Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-22-2005, 10:02 PM   #3
69 longhorn
I like a little nose down rake myself.....not a lot, but just enough to notice. asfar as advantage/disadvantage, on the street you will see no diffs either way. The old rule on the street /strip stuff , was taht an auto trans liked a pretty level stance......a stick shift liked a nosed down attituded, due to the hard chassis reaction that stick caused! stick shift vehicles really stand up hard L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 06-23-2005, 03:35 AM   #4
matthufham
on two wheel drive trucks, the front is lower, and when a heavy load is in the bed, the rear drops so the truck is level. on a 4wd, the front is higher to maneuver over obstacles.
matthufham is offline   Reply With Quote
Old 06-23-2005, 12:38 AM   #5
ac102nv
ac102nv's Avatar
as mentioed above, plus some of us run taller tires in the back and don't want too much rake. ie 1" taller tire, 2" shorter spring, equals slight rake. Just not as much as factory.
It's all personal preference...
'72 C10 lwb 454/TH400
ac102nv is offline   Reply With Quote
Old 06-23-2005, 11:38 AM   #6
70GMC_BOB
if you were to say use drop blocks in the rear of a 3/4ton, can you haul the same load, but it would just squat more? or is it not good for show??
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 06-23-2005, 05:31 PM   #7
matthufham
it probably will have no effect on hauling. and it will only squat lower because the truck overall is lower.
