Old 06-22-2005, 11:58 PM   #1
gefs55
1972 grill alignment
Was wondering if any of you have run into this problem. Have a 1972 c-10 have a new right fender, right inner well, radiator support and inner and outer grill. After replacing them the headlight is to low on the driver's side to let the headlight bezel go in. Passenger side fits fine. I have adjusted everything I can think of, including the height of the radiator support. Everything matches to the height of the frame. It appears the only damage to this truck when I bought it was to the passenger fender the rest was replaced because of age and rust. Any suggestions???
gefs55 is offline   Reply With Quote
Old 06-23-2005, 06:47 AM   #2
JimKshortstep4x4
Talking
I have never run into that problem. The only suggestion that I have is to try adjusting the fender to the radiator support. If it is only a little bit off you may be able to get it to work.
Good luck!
Jim
