06-24-2005, 04:29 PM | #1 |
Professional Grade
How does the door handle come off on these things?
Hey guys!
I've got the door handle unbolted, but I cannot figure out how the rod is suppost to come off the handle. I am busy prepping the truck for primer, as I cannot put the interior back together until I have the roof primed... Anyone have any idea? lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-24-2005, 05:23 PM | #2 |
Slots go on anything!
There is a clip that is a royal PITA that holds teh rod from the handle to the door lock mechanism. Once you get it free and the door handle bolts are both out, push the button in and jiggle the handle out. It is impossible to get the rod loose from the handle, the clip will need to come free at the lock. I find it easier to pull the lock loose to get at the clip. FWIW, the second one seems a whole lot easier.
1974 Jimmy- 5.3/4L80e/NP241 |
06-28-2005, 02:59 PM | #3 |
www.73-87chevytrucks.com
The clip has a locking tab on the end. If you place a small flathead screwdriver blade under the tip and push it down with another one you can pull the rod out.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-28-2005, 05:51 PM | #4 |
I have just the tool you need Russell.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
06-28-2005, 08:09 PM | #5 |
Professional Grade
haha, I was actually using that tool on the truck tonight! I showed those rivets who is boss!
06-30-2005, 09:54 AM | #6 |
Wait till you try to put it back on.........
06-30-2005, 01:04 PM | #7 |
Professional Grade
Which is why I decided I shall do some fancy masking tape work
06-30-2005, 02:26 PM | #8 |
my gas saver
question
is there an easy way to loosen the handle up so you can tape around it easier? i will be geting close to doing this soon.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
