Old 06-25-2005, 06:38 PM   #1
75stepside
*Proud Member*
75stepside's Avatar
Ball joint Spinning... lowering job
Putting in a set of drop springs today and when putting my suspension back together, the lower ball joint spins a little when tightening the castle nut... should i reach for the impact? is this normal?
75stepside is offline   Reply With Quote
Old 06-25-2005, 07:37 PM   #2
SCOTI
SCOTI's Avatar
Usually when the BJ spins, it's a sign of wear. It should be replaced. The cost of a new ball joint can be far less than the damage caused by one that fails while driving down the road.
That being said . . ..... if you wish to continue, 'tap' on the spindle to try to seat the BJ stud a little more. That should grip the stud better & keep it from spinning.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-25-2005, 10:06 PM   #3
SSC's76
No No
SSC's76's Avatar
I'd replace it just to be safe. Ever see a ball joint fail? I'm sure that $30 for a new one would offset the cost of a tow and possible damage
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 06-25-2005, 10:19 PM   #4
jermasaurus
jermasaurus's Avatar
If you must get it back together for now, use a C clamp to hold the spindel to the control arm.
-Jeremy
jermasaurus is offline   Reply With Quote
Old 06-26-2005, 03:44 AM   #5
1FaastC10
1FaastC10's Avatar
i'm sorry, but that has to be the dumbest thing i have ever heard. suspension, especially on the steer end of the trucks is one of the 2 things that you should not compromise, no matter what the circumstances. the other being brakes.
1FaastC10 is offline   Reply With Quote
Old 06-26-2005, 11:08 AM   #6
75stepside
*Proud Member*
75stepside's Avatar
what is the best way to pop the ball joints out?
Old 06-26-2005, 11:39 AM   #7
75stepside
*Proud Member*
75stepside's Avatar
Originally Posted by Riptide's 78p/u
most parts stores have a special press u can rent to pop it out..and pop the new one in...its an interference fit..so u need to press the old one out.and the new one in....just dont take a hammer to it!..unless u feel like replacing ur lower control arms.....
ya, i realize the press in and out... so, its probably easiest to just take the lower control arms totally off...???
Old 06-26-2005, 02:32 PM   #8
SCOTI
SCOTI's Avatar
No. Just contact your nearest parts house that rents tools. They should have a 'C-clamp' style BJ tool that will pop the old one out & then w/a few changes of the dies, press the new one in.
Pulling the arm off the truck might make things easier to work on, but it's not mandatory.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-26-2005, 05:39 PM   #9
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I did both of mine on the truck with the press. You can bottow one from most of the parts stores around here, or buy one at Harbor Freight when they go on sale, like I did. It makes the job pretty easy.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
