Old 06-28-2005, 02:23 PM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
Spring on front drums?
What are the springs wrapped around the front brake drums for? I have a noise coming from that area at low speed (30-45 mph) and it goes away above 50 mph. It sounds like it's either that spring rattling or a trim ring on the rim or something. Anybody know what it could be?
70STOVEBOLT is offline   Reply With Quote
Old 06-28-2005, 02:53 PM   #2
70c10
67-72 Addict!
70c10's Avatar
The spring is supposed to be for suppressing vibration. I was missing one on my front drum and replaced it and it made no difference whatsoever.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-28-2005, 07:28 PM   #3
Sweet72
Sweet72's Avatar
like 70c10 says it's supposed to reduce harmonics. brake drums can ring like a bell when they're squealing. too bad the search function isn't working cause there was a long thread on this very subject. The conclusion of the previous thread was that these springs are not necessary for normal brake function, however if a squeal developes you may notice a slight reduction in noise and embarrassment.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
