Old 06-30-2005, 05:25 PM   #1
sdkid
Drum to disc conversion ?'s
Found a mid-70's for a donor. I plan to swap the entire crossmember. Mine is a 1970 chevy c-10. Can I swap just the axle shafts in the rear, or is the housing different? Can I use the mid-70's booster and master cyl? Or do I need the older unit. I have manual drums now.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 06-30-2005, 05:36 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
There are 2 different axel lenghts fo the '70 model year. If you have the longer ones you can swap em straight across.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-30-2005, 08:35 PM   #3
krue
Designated A-hole!
krue's Avatar
The easiest way to do the m/c booster is to get a 71/72 m/c and proportioning valve.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-30-2005, 10:41 PM   #4
jamal
jamal's Avatar
what about a 67 are the axles different? I just bought a 72 donor truck
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 06-30-2005, 11:21 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
The 67 axels are shorter. I have herd of people either redrilling the axels for 5 lug or machineing spacers for the longer axels. Maybe you can use the whole '72 rear end?
ZIP 91351
Old 07-01-2005, 07:21 PM   #6
c10chevy69
c10chevy69's Avatar
Go with changing out the whole rearend Jamal. Get new u-bolts because your going to destroy the old ones and they are probably shot anyway. I did my 69 recently and I was a bear to get the u-bolts off until I got a compressor and a cut off tool. Like a hot knife thru butter.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 07-01-2005, 08:32 PM   #7
jamal
jamal's Avatar
Have a new set of chrome u bolts so no problem there. The only thing is I don't have the welding skill to weld the new brackets on.
Old 07-01-2005, 09:41 PM   #8
krue
Designated A-hole!
krue's Avatar
As long as they are both the same type of suspension you shouldn't have to move the brackets.
www.daveramsey.com
Old 07-02-2005, 10:56 PM   #9
jamal
jamal's Avatar
67 is coil spring parts truck is leaf
