Old 07-01-2005, 01:21 PM   #1
s95930
A-Adam A-Adam
s95930's Avatar
New rearview mirror
Needed to replace my rearview mirror in my truck. A new one like the original was just too much.
So I decided to go with one that glues to the glass. I went to the local salvage yard and picked one up that has map lights in it. I ran the wires above the headliner and wired it up. It came out pretty good I think.
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 07-01-2005, 04:10 PM   #2
Hart_Rod
Hart_Rod's Avatar
Nice job!
R
Hart_Rod is offline   Reply With Quote
Old 07-01-2005, 05:04 PM   #3
Joe67
67 is sold
Nice mod
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-01-2005, 05:50 PM   #4
BubbaGreen
I like that...ALOT!!!
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 07-01-2005, 10:21 PM   #5
70c10
67-72 Addict!
70c10's Avatar
That's cool. You should do a write up in our FAQ forum.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-01-2005, 11:30 PM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Did you remove and reinstall the headliner? Details please on how you ran the wires.
badpeanut is offline   Reply With Quote
Old 07-02-2005, 09:14 AM   #7
nitor
Too many projects
nitor's Avatar
That's a really good job. I need to replace mine, I think I'll consider the same thing. Although I don't have a headliner. I'll have to figure something else out on the wiring.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 07-02-2005, 03:41 PM   #8
mjrmn
'67 K10 Work In Process
mjrmn's Avatar
I replaced the factory rear view mirror in my 67 with a unit that has the compass and auto-dimming from a 2000 Silverado. No headliner in my truck either so I just tucked the wires into the windshield rubber down the drivers side to the fuse panel. Works well and no ugly wires hanging in the way
mjrmn is offline   Reply With Quote
Old 07-02-2005, 04:11 PM   #9
nitor
Too many projects
nitor's Avatar
So the wires fit under the rubber. Good for you. That's what I think I'll do. I would have thought they would force the rubber to stick out enough to be noticeable.
Jim
'04 Chevrolet Astro
Old 07-02-2005, 10:41 PM   #10
s95930
A-Adam A-Adam
s95930's Avatar
My headliner is loose so that helped.
I drilled a small hole under the original mirror base cover. Then I had to drill a hole under the modling for the headliner. Pulled the wire through the holes. Pulled the wire across the top of the headliner. Drilled another hole under the molding then pulled the wire to the dome light. I also had to route a wire to a door swtch so they would go on and off with the doors opening and closing.
Does any of that make since?
Old 07-02-2005, 10:46 PM   #11
armyavncowgirl
C10 Junkie
armyavncowgirl's Avatar
nice job! i'm thinking of doing that too when i change out my windshield.
also, i noticed the ribbons on your glove box
Hope you all have a wonderful 4th of July
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck
Former rides:
1967 C10 LWB
1972 C10 LWB
1969 C10 LWB (parts truck)
armyavncowgirl is offline   Reply With Quote
Old 07-02-2005, 10:51 PM   #12
s95930
A-Adam A-Adam
s95930's Avatar
Put them there when I washed the truck. Need to get them back on the outside.
And thank you for serving.
Stay Safe.
Old 07-03-2005, 12:24 AM   #13
KEH
Better late than never
KEH's Avatar
Great upgrade! It is on my list now.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 07-05-2005, 09:52 AM   #14
KEH
KEH's Avatar
Does a mirror with a compass have a sensor that needs to be pulled also, or is it built into the mirror?
Old 08-10-2007, 02:15 PM   #15
badpeanut
badpeanut's Avatar
Re: New rearview mirror
Old post, but good question. Anybody know the answer?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
Old 08-10-2007, 03:15 PM   #16
70GMCer
70GMCer's Avatar
That is a nice setup. I did mine about a year ago. Drilled a small hole inside where the original mirror cover went, then fished some 18/5 strand wire through the top of the headliner to the back. Then drilled another hole so that I could fish the wire down to the inside dome light opening, and then on down through the cab and to the fuse box. I wired the dome light to come on only with the headlight switch. I installed bottom courtesy lights under the dash to come on when the doors are open. I installed the extra wire count (5) at the mirror for future use. Like when I find a mirror that does outdoor temp. Then, I'll have the wire for the sensor already waiting.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-10-2007, 07:16 PM   #17
mjrmn
mjrmn's Avatar
If it has the compass only it is built in - just need the switched power wire to make it work.
