07-01-2005, 09:17 PM | #1 |
filler neck install advice
Any advise is most welcome. I tried for 2 hours and still don't have it installed.
07-01-2005, 09:25 PM | #2 |
Designated A-hole!
Where are you trying to install it? Stock location behind seat or under bed blzer style tank?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-02-2005, 10:30 AM | #3 |
If your talking the stock one. I think I had the tank out, put the rubber gromet thing in the cab hole. Then from the pass door sort of aimed the filler neck through the gromet. Kind of awkward but it wasn't too bad. I had an old but in good shape rubber part, so it was a little " dry" and it slid ok while still being tight. A new rubber part that was "sticky" might be a lot harder. If your not talkin stock tank please disregard this entire message.
I got a bench seat baby, you don't have to sit over there. |
07-02-2005, 10:55 AM | #4 |
lube grommet with soapy water
07-02-2005, 07:33 PM | #5 |
It is the stock filler neck. The glass people who were installing the winshield let me use there spray silcone. I started at the top and when I got to the bottom, there just wasn't any room to push the gasket in. I might trying loosening the tank and going from there.
07-02-2005, 08:09 PM | #6 |
Project Junkie! Fishing Poor!!
You need to remove the tank to install a new grommet. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-02-2005, 08:28 PM | #7 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
07-03-2005, 12:09 AM | #8 |
67-72 Addict!
It sounds like you have a 71/72' tank (2") and are trying to install a 67-70' gromet (1.5"). Double check that first.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-03-2005, 03:00 AM | #9 |
I just pulled the tank on a '72 K20 pickup I just...,er, picked up. Removing the seat was more difficult than removing the tank. My impact wrench made quick work of the tanks bolts. From underneath, I first wire brushed the threads and sprayed on penetrating fluid. Pulled the little hose at the sender first and the sender harness. I siphoned out most of the fuel first, too. The tanks is unwieldy. Significant fuel weight makes things difficult.
With the tank out, I can more easily guide the neck thru the grommet. I have silicone, as well. I also removed six inches of mud from the cab corners. No worries, it's a clunker.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
07-03-2005, 01:07 PM | #10 |
#16876
Im missing something. I pushed the old one in, and cut it off. I lubed up the new one and slid it on. I worked the filler neck grommet on by hand. Fits good.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
07-04-2005, 01:18 AM | #11 | |
You obviously have skills. As for the rest of us.....
07-04-2005, 03:11 PM | #12 |
As stated before, use some type of liquid hand soap and be patient. Put the gasket in first and then lube the neck and the inside of the gasket, this is a two person job , one to persuade the tank through and one to hold the gasket so that it does not slip out. This will work but do not get in a hurry.
07-05-2005, 07:40 AM | #13 |
blood type; Retumbo
silicone dielectric grease does wonders. I learned this doing an oil cooler on a powerstroke.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
07-06-2005, 06:28 AM | #14 |
You're so right, 68C15. I've got a little tube of silicone. Works wonders on any effort to install rubber hoses. Only takes a tiny dab or two the size of a bb to ease sliding on a radiator hose. Silicone takes heat well and is harmless to rubber, too.
