Old 07-02-2005, 11:26 AM   #1
newin72
any body tried this? (r12 replacements)
http://63.135.115.175/products_refr.html
or this:
www.duracool.com
any luck with either? or what other options do you prefer?
newin72 is offline   Reply With Quote
Old 07-02-2005, 02:38 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Never heard of those. I'm well stocked with 134A and R-12 for awhile.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-02-2005, 08:36 PM   #3
HuggerCST
HuggerCST's Avatar
Never used thoses, but I've been using "Freeze 12" as a drop in replacement in the state vehicles that I maintain for a couple of years now, and have had no problems at all.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 07-02-2005, 10:29 PM   #4
Josh
He's got mean nasty FANGS!
Josh's Avatar
Freeze 12 is the best r12 replacement I've found and used, it cools about like 134a, but is more friendly to an R12 system... Never heard of the others.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 07-06-2005, 03:21 PM   #5
Gene
Gene's Avatar
Hey Josh, I had my system recharged with freeze12 and I was wondering, how cold should it be getting? The coldest reading I have gotten is 50 degrees. My brother in law filled it and he put in the oil charge 8oz. and two and a half 12 ounce cans. But there is still bubbles showing in the sight glass on the dryer. I always thought if there were bubbles that it was low on freon?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 07-04-2005, 01:20 AM   #6
4x4Poet
ttt
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-04-2005, 07:01 AM   #7
Terry Peerson
I use this stuff called "Autofrost" in my '72. It works very well in an R12 system. Cools the air at the vents down to 40° F. I bought a 25# Bottle about 3-years ago. The truck leaks a bit and I have to add a pound or two every year. I'll probably buy another bottle next spring.
Good Luck!
T
Terry Peerson is offline   Reply With Quote
Old 07-06-2005, 01:33 PM   #8
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
The info on the duracool sire alludes to R134 eventually ending up on the chopping block with R-12. Instead of ozone depletion the hazard is supposed to be global warming.
I don't consider myself to be the tree-hugging type but I do try to keep my hazmat down to a minimum. This stuff is supposed to be 30 odd percent more effiecient than R134 and about the same performance as R-12. Price is a lil more expensive than R-134. All that said, I'm interested.
I have nearly all of my a/c bits and pieces together. I just need some hoses custom made and a few lines bent up. Hopefully, I'll have it up and going before winter hits. It's a money thing ya know. Still on the fence for the refrigerant. If I use something other than 12 or 134 I'll post my results. Don;t hold your breath though, winter is a few months away.
If anyone does have experiance with the hydrocarbon refrigerants, I too would like to know about it.
Edit: Newin72, thanks for the heads-up. I would have never found this info otherwise.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 07-06-2005, 04:33 PM   #9
newin72
Gene, did you pull a GOOD vacuum on your system first?
Old 07-06-2005, 05:28 PM   #10
Gene
Gene's Avatar
Yes, he pulled a vaccum and it held at 22 psi for over an hour.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
