07-03-2005, 07:15 PM | #1 |
Psalm 23
Mounting the heater control...??
Like the title says I'm trying to mount the heater controls in cab but I'm not sure what size bolt..or what kind of bolt is used to mount the thing.
Can someone tell me how the heater control is normally mounted in the dash...thanks. From what I can tell I need a screw...or bolt that goes head side on the front of the dash and screws into the heater control unit. I just don't know if I'm supposed to put a washer and nut on the backside of the heater unit or just have a regular screw. Any help..pics anything would help thanks.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
07-03-2005, 07:43 PM | #2 |
They were a star head screw. No washer. Same kind of bolts that hold the filler piece under the coloumn only longer. Kind a specific screw.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
07-03-2005, 07:52 PM | #3 |
Psalm 23
Can I buy them anywhere?
07-03-2005, 08:24 PM | #4 |
I believe the two screws have 1/4-20 threads, and are about 3/4" long. They are Phillips head type. They pass through the lower edge of the dash from the front and thread right into the heater controls. I don't believe there are any washers or nuts used.
Try going to www.mcmaster.com and enter in part number 90272A540. If you have an Ace Hardware in your town, you could probably buy this style of screw there, maybe even in stainless steel. |
07-03-2005, 08:48 PM | #5 |
Psalm 23
Cool thanks alot...I believe theres an ACE hardware around here somewhere.
