07-05-2005, 08:27 PM | #1 |
Installing insulation / sound proofing and carpet
I just installed the Jute insulation and sound proofing on the floor and back wall of my truck. I started calling around about carpet and found that several suppliers include sound proofing and the Jute pad sewn into the carpet.
Does anyone know if I will run into problems using the carpet with the pad sewn into it along with the pad I have already installed? It will be about an inch thick, should be well insulated but my concern is things not fitting right like the sill plates, seat and gas peddle.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
07-05-2005, 08:34 PM | #2 |
C10 Club Tennessee
I would think the more the better, to a certain extent.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
07-05-2005, 08:39 PM | #3 |
Keep in mid that Molded carpet with padding is molded to fit your bare floor. If you have more padding it may cause the new carpet to not sit right around the tunnel and other molded areas.
Kevin |
07-05-2005, 09:50 PM | #4 |
a problem with using alot of jute padding in the florida climate is it will abrorb moisture and start to get mold and mildew as well as promote premature rust, as well as being an excellent breeding ground for insects other than that it's ok
www.coollizard.com
07-06-2005, 01:11 AM | #5 |
I agree with Rokcrln. I work in an upholstery shop in Washington and the truth is, if you put molded carpet with jute on top of another layer of jute, you will run in to problems like it not fiting like it was intended to and it will be a pain to line all of your floor mounted accesories and what not. I have layed two layers of jute before, but the customers always have it re-done. The choice is yours.
07-06-2005, 07:23 PM | #6 |
Thanks for the replies, I had several of the same concerns, didn't think about mold and moisture though.
Can anyone recommend a vendor that has carpet without a jute pad?
07-06-2005, 09:18 PM | #7 |
I buy my carpets from auto custom carpets. There web address is accmats.com. You can call them and ask if the carry carpet without jute. It just depends on the vehicle usually.
