Overworked and Underlaid
WTF is wrong with my truck.
ok on tuesday morning i went to go to work and my truck wouldnt start.the battery was 2 years old so i went and got a new one.still wont start.go have the alternator tested.alternator good.had it tested b/c it came with the truck i parted out to get this one running so i wasnt sure of its condition.pull starter out today-had it tested which it tested good and did the screwdriver across the two terminals trick and the starter still engaged and seemed to be working properly.im now thinking it was the solenoid or either the igniton coil or ignition module.im at my wits end here.so WTF is wrong with my truck.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
AttentionDeficitDisorder
did u try putting a remote starter on it? possible loose wire, ignition switch, fuseable link etc?
'87 V20 4x4
mpre than likely sounds like a inline fuse trace the wirse from the battery to the firewall and there should be a box there with wires coming from it that has inline fuses in them just use a wire tester to check them this is what happened to my 86 blazer drove me crazy for a week
Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 ![]() ![]() |
sometimes stater wires melt on headers and short themselves to the ground? this happened to me once.
I'm back with 2nd truck!
Is it even cranking? If it is then it sounds like either a fuseable link between the starter solenoid and the HEI.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
can you run electronics, but not start. you should charge the battery in that case. when you drive short distances you use so much voltage and you end up with not enough cranking volts, but it'll play the radio fine. i have a battery charger and every now and then i charge mine for a couple hours. after that, starts right up.
if its not doing anything when you turn the key, i would try putting it in N, as the park/neutral safety switch could be out.. if that doesnt work, it could also be your ignition switch/module (on top of the column that is operated by a rod when the key is turned).
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Nobody rides free
![]() Join Date: May 2005
Mine did the same thing ..... the morning I went to get my new tires mounted
'71 C10 LWB 400SB/350TH ![]() '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
