07-11-2005, 10:02 PM | #1 |
Need pulleys bad! Help!
I'm copying this from the 60-66 board but surely someone can help. I am needing a water pump pulley for 283 or 327 V8 with a/c. It is a 2 groove pulley with a space between them. The first 2 pics are for a 283. It is actually 2 pulleys that bolt together. A shallow pulley mounts on top of the generic single groove pulley that is on almost every non-a/c V8 from the 60's and early 70's. I need the shallow one. The third picture is of a 327 pulley. It is a single piece cast iron 3 groove pulley. I really need this one but would buy the 283 style if anyone has it. Thanks for any help!
Joshua |
07-12-2005, 08:27 AM | #2 |
55454
I have a double upper, and a triple split bottom 66 327, pm your e-mail if you want pics.
Would rather trade than sell. |
07-12-2005, 02:08 PM | #3 | |
Bloo
in order of pics,
#1 shows all 4 #2 shows 3 groove lower, with outside one being larger, $20 #3 shows 3 groove lower, all same size, $12 #4 shows 2 groove upper, small, came off long water pump, $10 #5 shows 2 groove upper, larger diameter, not sure what its from, $15 i would be interested in a single groove upper, or a double groove lower, for a short water pump, as a trade pm me if your interested
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-12-2005, 02:16 PM | #4 |
55454
Huggercst has the top pully for sure. What I have will be tin. I will send pics when I get home. I am not claiming to be an expert but that upper cast pully would be identicle to a 1968 327 Chevrolet pickup w/ac wo/ps. The bottom p/s belt looks like it is in the fourh position maybe for a power assit. Wynne definitley has the top, I sent the bottom double to another board member off the 1968 which had the first and 2nd position from the harmonic balancer for alt and a/c. Are you using the pre 1969 a/c set-up. It seems before 1969 on the p/u the ac and power assit were out an extra space due to the positioning of the a/c compressor ;hence, the extra space on the water pump pully. I am sure you have all this figured out, I am personally trying to find out the difference between a 68 and 69 lower triple pully. I will do what I can to help.
expect pics by 18:00 central. 72 BB 68 C/10 14 year old Chihuahua (factory teeth) Black 92 wheel barrow over inflated tire for lift (compromises ride). |
07-12-2005, 08:01 PM | #5 |
I just took that cast waterpump pulley out of my truck sunday. I'll try to snap a pic of it this evening. Thanks
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
07-12-2005, 09:32 PM | #6 |
"Trucks with Class"
It looks like you have it covered, now, but here is another one for you to look at. It is a 3-pulley short wp off one of our trucks.
07-13-2005, 01:47 PM | #7 |
Thanks for all the help guys. I'm still holding out to see if anyone has the cast water pump pulley in pic 3. I am collecting parts for a future 1966 Custom Cab project. I'm pretty sure that pulley is the correct one for 327 with a/c. I drove 60 miles to take pictures of an original loaded 66 (pic. #3). I'm thinking that this same pulley may have carried over into 67 or 68.
Joshua |
07-14-2005, 10:31 PM | #8 |
"Trucks with Class"
OK, now I think I know what you want...This cast set is on a 68 327 GMC I just got in.
07-15-2005, 05:53 PM | #9 |
That's it, pickmup! HuggerCST ended up having one. Thanks for all your help.
Hugger, payment is on the way. Joshua |
