07-12-2005, 12:50 PM | #1 |
1987 GMC Sierra Classic
AC Compressor
Does any one know if there is a rebuild kit for auto ac compressors? My 87 GMC compressor is getting really noisy and starting to cool poorly. I am not sure if I want to spend the 190.00 for a brand new one.
Gary L Hilton jr |
07-12-2005, 02:30 PM | #2 |
No No
There are clutch kits for them but they can cost nearly as much the whole compressor. I'd just go for a cheap $120 re-man compressor. I havent seen any issues (manufacturing defects) with the cheap parts store re-mans after all there rebuilt by the same place that made the OEM unit for your truck.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-12-2005, 05:43 PM | #3 |
Check www.napaonline.com
As cheap as $105 for a reman compressor, I have one on my truck that has been working great for years. (Mine is also converterd to R-134a)
1983 GMC Sierra Classic 6.0 LS / 4L80 swap in progress |
07-17-2005, 12:07 PM | #4 |
Thanks, I think I'll go with the reman.
Gary L Hilton jr Last edited by GMCLS1; 07-17-2005 at 12:08 PM. |
07-21-2005, 01:36 PM | #5 |
Not a bad nut after all..
Injected83GMC, could you provide details on your R-134a conversion?
07-21-2005, 02:02 PM | #6 |
I just put one on my 1985 Blazer from Advanced Auto for around $100. Works great so far.
07-21-2005, 02:36 PM | #7 | |
No No
Although you dident ask me. The kit is $45 comes with 3 fittings that you screw on 2 are for american 1 is import, 3 cans of R134a+ oil and a hose with guage usually. Replace fittings screw can into hose place it on the low side "blue cap, large accumulator line" start engine turn ac on high press the button on the hose or release the screw valve, turn can upside down and shake until empty. You should only need two of the cans that come in the kit. The kits with guages will show pressure dont exceed 45 PSI, 38-40 is fully charged.
07-21-2005, 07:18 PM | #8 | |
