Brake line needed.
I am in need of the brake line on the rear passenger side axle. I have a 10 bolt coil rear 2wd. Where it goes into the tee it is 1/4" I believe. the other end goes into the brake drum housing. all I need is the short line. Any help would be great!!! Thanks JIM
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
If you can give me to at least the weekend I might be able too help. I will need to look and make sure the one I have is in good condition.
If you don't hear back by Saturday drop me an email. thejoker(at)gatewayriders(dot)org . |
No problem!! Thanks
I'm watching you!
If that doesn't work out you can pick up a piece at your local auto parts store pretty cheap. Just bend it by hand into shape.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
#5 | |
I'm watching you!
Hmmm weird. OK just a thought. Good luck on your adventure.
Mike
Somethings weird most all drum brakes use 1/4 line, did you get a 3/16 fitting to screw into it? Are you sure the wheel cylinder has not been replaced with a newer metric cylinder by mistake? 1/4 x 3/16 adapters are available from NAPA it is the same adapter used when putting a disc brake front end on a drum brake truck. What year is your truck with a 10 bolt rear?
Rest in Peace Ed. Thanks for all the good times. Last edited by MOTHERTRUCKERS; 07-13-2005 at 07:05 AM. |
#8 | |
