07-13-2005, 04:42 PM | #1 |
383 Stroker - Not Enough Power!
We just put a 383 Stroker in my son's 71 Cheyenne SWB. It has all the goodies, RV cam, Heads, Pistons, Headers, etc. And has been bored to .60 over. But like most kids, its not enough for him. We just had the heads redone with bigger valves, 1.94 to 2.02. Since the top end of the engine is apart, he wants to change it from hydraulic lifters to rollers. What do we need to change to make it a roller engine? Can we just replace the lifters and rocker arms with roller rockers and roller lifters? Or do we need to change cams and other parts too? Also how much more power could we expect to gain? It had about 400hp/425ft-lbs, before the head work.
Edit: Also does it make a difference between hydraulic rollers and solid rollers? Or is there a hydraulic cam out there that could give it the same power gain as changing to rollers, without losing too much streetability?
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay Last edited by Swbman; 07-13-2005 at 05:38 PM. |
07-13-2005, 04:55 PM | #2 |
graphic designer
gonna need a new cam, different profiles for roller and flat tappet. and possibly cam button/thrust plate thing to keep it from walking forward. it would be easier to add some sort of power adder (Nitrous, Supercharger, blower, etc...) how old is this kid? a 383 not enough power? sound like big block territory to me. maybe a 427 World Products small block, all aluminum, full roller...
07-13-2005, 05:00 PM | #3 | |
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
07-13-2005, 05:19 PM | #4 |
Blank
you never can have enough power!!
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
07-13-2005, 05:37 PM | #5 |
rv cams aren't real power makers they're for moving rv vehicles down the road with economey// get all your specs laid out in front of you and call a couple of cam companies tell them what you've got and what you want they'll tell you what they've got to solve you problems// they have specialists just waiting for your phone call
07-13-2005, 05:44 PM | #6 | |
Keep On Truckin'
Exactly what I did when I built my last car motor. Time well spent with the cam experts.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
07-13-2005, 06:00 PM | #7 |
A roller cam is an expensive proposition. 300.00 springs..400.00 lifters..300.00 cam..most likely longer valves..different pushrods..a cam button..a distributor gear(bronze).
If he wants more power right now..then a cam like the comp xs268s10 will do it in spades. You can use the stock springs. It is a solid flat tappet. After initial breakin..check the lash when you change the oil. This cam will make 40HP more over an RV cam.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
07-13-2005, 06:46 PM | #8 |
I'll trade ya my stock 350 to start over on for that 383, thats plenty of power for me.
-Cory 1967 2 Wheel Chevy |
07-13-2005, 07:06 PM | #9 |
~Rest In Peace~
what tranny are you using if auto maybe a t/c is needed higher stall or what rear end gearing do you have these might be your problem
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
