07-14-2005, 12:02 AM | #1 |
Rear Seat Ideas
I thought I wanted to use third row tahoe seats with integrated seatbelts in my blazer, but after reading this post
http://67-72chevytrucks.com/vboard/s....php3?t=163641 I have questions. They are talking about the fronts (which I'd like to use integrated seat belted seats out of an HD), but I am more concerned with using the rear "fold away" seats. I planed to use extra bracing under the bed and build a subfloor with steel to use the original mounting hardware. I'm not sure this thread has provided many answers. Does anybody have plans to do something like this, or have done this? I know Jamie did and I thought it looked solid. I will have two children occupy the rear seat and I don't want to take any chances. Any suggestions?
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
07-14-2005, 06:54 AM | #2 |
Use whatever seats you like.
It's the seat belts that are making it all an issue. Go for the comfy seats you had in mind and just use the blazer factory belt set up. My kids have logged tons of miles/smiles in the blazer, just make sure the lap belt is around their little hips and not across the tummy. |
07-14-2005, 08:52 PM | #3 |
The LuvShack Garage
It's all about what makes you happy that counts
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-15-2005, 09:37 PM | #4 |
I wanted to use the integrated seat belts. I guess my question is whether or not to use the seats with the integrated belts. I agree with the what makes you happy plan and I liked the idea of the integrated seat belts. If they are a problem, I could easily, and more cheaply use the 3rd row seat from say a 99 suburban and use the factory belts.
07-16-2005, 09:13 PM | #5 |
I built a full roll cage out of 1.75" .225" wall DOM tubing.
No issues mounting whatever I want |
07-16-2005, 09:18 PM | #6 |
You used third row seats out of a 2001+ Tahoe and the integrated seat belts. I didn't think the rollbar would be a problem, but I was worried about the safety of the integrated seat belts.
07-17-2005, 06:21 AM | #7 |
You neeed that plate you're talking about to go under the bed.... same goes for the roll bar, if the backing plates arent there bolts and nuts will get pulled right through the floor god for bid...
07-17-2005, 10:11 PM | #8 |
Regardless of which seats I decide to use I'll be using plates on the underside. I have plates for the rollbar already.
07-18-2005, 06:06 PM | #9 |
I have plans to use the third row seats from a 2001 or newer to get the integrated seat belts that way the passengers have shoulder restraint
08-03-2005, 11:14 PM | #10 |
Sorry if this is old news. I am using a brand new third seat removed from a 88 Suburban. I am also installing the floor brackets as well so it can be used as it was originally intended.
Mike |
08-04-2005, 10:47 AM | #11 |
go cyclones
I used third row seats from a 2002 tahoe. They worked out pretty well i will do a search and see if the pictures on still on the site
08-04-2005, 08:05 PM | #12 |
Active Member
Do the third row Tahoe seats fit between the fender wells like the original seats? Can someone provide the dimensions of this seat?? What about the seat mounting, does it mount "as is" or do you need to fabricate a mount? I like the idea of using these seats as it will match my front buckets from a 2000 Silverado
08-04-2005, 11:40 PM | #13 |
go cyclones
yes they are a perfect fit, you will have to fabricate a mounting system. They hook into half inch rods
