what is this noise??
i decided to go out for a drive tonight and about 3 miles from home i statred hering a clunking sound. I turned down the radio so as to to try to here ware exactly ware it was comeing from or what it could be. from my determinatin it is come in from the rear half and only clunks wile cousteng. as i drove home it got worse but i cant figuer out what exactly it is any ideas?
i love summertime
rear end?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
if it was the rear end wouldent it lock up ? it drives fine less a little vibration, its definetly in the drive line though
its all about the +6 inches
u joint
Do you have a posi-track rear end? You need to replace the gear oil and include the posi additive.
1969 C-10,short bed, I6 250, 3x1 offy, HEI, headers, 5 speed, original paint and family owned! |
thats what im thinkinbut with it bein dark and the side pipes hot i really wasent all into crawlin under there
no i dont think that is it ill just look in to it in the morning
If it has a 2 piece driveline sounds like mine did with a bad center carrier.
I make Models
![]() Join Date: May 2005
Just had a similar problem with mine......ended up being the carrier bearing letting loose.....get it checked before you do real damage....JMHO
real damage
![]() ![]() Join Date: Jan 2005
Ouch!
maannnn, no one woulda ever guessed it was yout tranny fallin out.
blood type; Retumbo
is this the full covered cast iron housing or the later aluminum one? if needed I have 1 of each hanging in the garage
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
