07-25-2005, 10:52 PM | #1 |
DJM 73-87 drop spindles on my 64
Hey guys,
I forgot to ask an important question before I order my drop spindles., I know I will need to change my upper ball joints, but what about my linkage? Will I need to swap tie rod ends or anything to make my spindles fit? If so what will I need and would it just be easy to replace everything or is there a simple way to change only parts of the front linkage. Thanks Keith |
07-25-2005, 11:04 PM | #2 |
Yes you will with the tie rods. Just find a doner truck. Thats what i did
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
07-25-2005, 11:19 PM | #3 |
can I get away with only swapping tie rod ends? Will the newer tie rods bolt up to my stock suspension or do I have to get some sort of adapter?
Keith |
07-26-2005, 01:07 AM | #4 |
I am not sure but I believe they wont match up. I ended up just buying a complete front end from a 73+ for $300. Might want to do that b/c you still need the brakes and then you have everthing else you need
07-26-2005, 01:29 AM | #5 |
Thanks for the advice!
That is what I was thinking, I plan on swapping everything over from a donor truck and then buying new discs, pads and lines. Thanks Keith |
