07-27-2005, 12:53 PM | #1 |
Adding Power Brake Booster Questions
My 71 has manual brakes.
Can I just remove a booster and bracket from another truck and install? Could it be that easy? I'm thinking maybe need to change the rod from the pedal...? Use the same master or install the one that's currenty on the booster? I'd rather not need to 'open' the system but thought I'd check to find out if there's some answer out there. Thanks. |
07-27-2005, 01:06 PM | #2 |
Yup, it is that easy. (hey, if I did it - it must be)
You will need the power rod, the manual one is too long. You can use the same MC. Here is my install: http://67-72chevytrucks.com/vboard/s....php3?t=163387
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
07-27-2005, 01:07 PM | #3 |
Java Mechanic
There is an faq on that.. basicaly -- you can use the same master, you'll need a new rod (not the same length) and everything basicaly bolts up .. you need to tap the vacume from the manifold, of course.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
07-27-2005, 01:08 PM | #4 |
also see this
http://67-72chevytrucks.com/vboard/s....php3?t=165344 |
07-27-2005, 01:48 PM | #5 |
Still Green but learning
Great info guys, I had the same question a while back. If I get a new booster from car quest it does not have the rod with it, where can I get one?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
07-27-2005, 04:51 PM | #6 |
Watch out for your cornhole !
Here's three pictures that I took when I converted my truck to power brakes.
You need the linkage and brackets that go between the booster and firewall. The rod that comes out of the brake booster is not the rod that connects to the brake pedal. There is an intermediate linkage between the booster and pedal. Study the pictures and you'll see what I mean.
07-27-2005, 05:57 PM | #7 |
Great info, thanks guys.
Next time up to the shop, I'll get-r-done. Thanks again. |
07-27-2005, 06:25 PM | #8 |
My son, my joy.
Can I put a booster on my 4-wheel drum braked truck?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400. Founding member of the No Money To Spend On My Truck Club. When your at Home Depot, you WISH you had gotten an 8 foot bed! |
07-27-2005, 10:25 PM | #9 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-27-2005, 06:29 PM | #10 |
Sorry to tell you this
Yes it's that simple.
You have to bend the break lines a little and add the vaccume hose but it's really easy. |
07-31-2005, 09:40 AM | #11 |
Designated A-hole!
Now you're not getting that workout every time you stop.
