07-31-2005, 11:14 AM | #1 |
Premium Level Member
Need some Gauge wiring help(stock)
How do I wire the following stock guages. I removed PO S&W gauges and am installing a stock setup
1) Amp Guage - do I wire to the fuse box some how? 2) Fuel Gauge - I do have a wire at the fuel sender, but nothing was connected at the dash on old gauge, now I don't know what to connect, ground etc. 3) Temp - I think I have to buy a new temp send and wire up, the old S&W guage had a sender that was part of gauge, so I can not resuse. I've got the other gauges covered, If you have a Pic that would be great but also hard to do
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
07-31-2005, 07:53 PM | #2 |
member #16
Here is GMC Pauls page on the guage wiring for converting to guages from idiot lights. scroll down page. Heres a pic of the wires in the engine compartment for the ammeter. These are the wires with 4 amp fuses inline you will need to add if your truck did not have guages from the factory. The wire from fuel sender plugs into fuse panel, I believe it is marked fuel sender. John
http://www.gmcpauls.com/Tech%20Tips1.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-31-2005, 08:10 PM | #3 |
Thanks for the post. I just got back in from day of working on truck. I found the plug that goes to dash and plugged it in....and gauges work. Feel dumb for the question now! The PO had disconnected it to run aftermarket gauges.
