Old 08-01-2005, 08:04 PM   #1
Orence1
Orence1's Avatar
Steel Cowl Scoop
I posted a while back looking for a company that sells steel cowl scoops. I am not looking for a hood, just the scoop. Somebody sent me the right link and I thought I had saved the URL but apparently I did not. Can any of you guys help me out with this one? Thanks in advance.
Larry
Orence1 is offline   Reply With Quote
Old 08-01-2005, 08:25 PM   #2
neonlarry
neonlarry's Avatar
I don't have your answer but this might help if the link was posted in your thread. Go to user CP on the right go to subscribed threads, this should show all the threads you have posted in if you are subscribed. It works even though there is no search function.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-01-2005, 08:43 PM   #3
Orence1
Orence1's Avatar
Neonlarry,
Perfect!!! Thanks for the help.
Larry
Old 08-01-2005, 09:47 PM   #4
71cadc10
71cadc10's Avatar
I've used this place's product on my cadillac, I was pretty happy with it.
the speedcenter
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 08-02-2005, 09:00 AM   #5
UP GRADE
one set closer
UP GRADE's Avatar
has anyone put one of these on a 67-72 truck. not a bad investment.
http://www.thespeedcenter.net/SpeedC...meFrameSet.htm
UP GRADE is offline   Reply With Quote
Old 08-02-2005, 01:39 PM   #6
71cadc10
71cadc10's Avatar
I put one on this hood. It's is a decent product all in all. Comes way long so you can put it as far front as you want. The cowl had a few waves in it that needed filler/glaze to smooth out (it was stamped like that), but overall I was happy with the result. I think it would go on a truck hood just fine.
A plasma cutter, and 1/2" air flanger made the job much easier. I cut the opening all the way around, so the scoop sat on about a 3/4" lip. Then flanged the lip all the way around so the flange on the scoop would sit down in it flush with the top surface. tack welded all the way around about a 1000 times. grind/fill/glaze/high build surfacer/paint
