06-25-2002, 11:41 PM | #1 |
72 Cheyenne
Front end question
Okay, I just put new shocks on today and the ride is much better but when I hit pot holes my truck still goes bam! What should I check? Everything looks pretty good, I'm stumped.
06-25-2002, 11:52 PM | #2 |
Collector of rusty Items
Do you have a sway bar? If the bushings get worn, they will cause a bang.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
06-26-2002, 01:24 AM | #3 |
Another thing to look @ is, the shock mounting studs. Where these bolt to the frame, the hole can wallow out, causing a bang when hitting a bump. good luck, steve
1970 long fleet, 355 4 speed, primer, walnut goodies |
06-26-2002, 10:30 AM | #4 |
check your upper and lower control arm shafts they get loose in the bushings and bang all around.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
