Old 08-05-2005, 08:58 AM   #1
fade94
fade94's Avatar
Oil gauge ok? How to wire batt gauge?
Is there a way to test it? At idle, mine is showing a little over half. Anything above idle RPM pegs it. PO said that the motor has a high flow oil pump. I do NOT want to put aftermarket gauges in. Unless I get one of the dash covers with them built it Just curious if this is normal for the oil gauge reading.
Batt gauge. My alternator has been upgraded to a single wire and the external reg has been eliminated. What is the correct way to wire up the batt gauge for this setup?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-05-2005, 03:26 PM   #2
pjmoreland
pjmoreland's Avatar
I had a high-flow oil pump in a 67 a few years ago and it acted the same way as yours.
pjmoreland is online now   Reply With Quote
Old 08-05-2005, 04:29 PM   #3
byrd
Union Electrician
byrd's Avatar
Check the faqs for the altenator and gauge hook up, as for the oil pressure gauge you have a 60 lb gauge and for the high flow oil pump you have you need a factory 80 lb gauge, which there are people on this board have some they might part with if you request to buy the gauge on the parts board, be prepared to spend a little to get a nice stock 80 lb gauge...... Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-05-2005, 04:43 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Look around the junkyards for the medium duty c40-c60 series trucks. If they have a big block(366-427), they'll have the 80lb oil pressure gauges in the dash.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
