Old 08-05-2005, 12:59 PM   #1
jec
jec's Avatar
Big Block 4WD
Has anyone done this?
My truck was converted many years ago and I have owned for 7 years. The engine is the original 402 and a manual SM465/NP205 combo was installed. The front crossmember and 2WD suspension was completely removed. A 4WD crossmember and frame mounts were installed, probably from a small block 4WD truck.
After dismantling the truck (see previous posts for pics) for restoration, I have noticed both left and right exhaust manifolds have been rubbing on frame. This driver's side is also cracked and may have been caused by the contact.
After a little research, I believe the motor mounts are wrong for this application. The engine needs to sit about a 1/2" higher.
Does anyone know the type of mounts that I could use for this?
jec is offline   Reply With Quote
Old 08-05-2005, 06:16 PM   #2
CraigS
I think mine are for a '74 or so vintage 454 in a truck. They sit real low as well, but they don't contact the frame.
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
