Old 06-26-2002, 09:31 PM   #1
Mountain Man
Need help - heater seems to be stuck on
O.K., so my truck is getting very hot in the cab. I discovered that heat is blasting out of the center floor duct, even though my heat control is all the way off. Is it possible that it is stuck open, or my dash control is binding some where.
Before I go crazy and start ripping and tearing, is there a way to close a flap or something inside that center heat duct.
The truck is only a fair weather summer driver, not driven in winter so I don't even need the cab heat.
What is the quickest way to block the heat from blowing out my center floor duct???
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-26-2002, 10:21 PM   #2
WORNBRAKES
If I'm not mistaken there is one wire that runs into the front of your fuse block with a terminal end. Blue I think. If you pull that wire your heat should not work at all. Hope this helps.
Mario
P.S. If that dont work maby try some duct tape. lol
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-26-2002, 10:21 PM   #3
Sierra
Sounds as if the heater control valve may have failed open. If you lose vacuum to the valve, which is supplied by a small rubber hose, it will open and allow hot coolant through the heater core. The valve is mounted on passenger-side inner fender on my truck. Hope this helps.
Sierra is offline   Reply With Quote
Old 06-27-2002, 12:39 AM   #4
too many
too many's Avatar
If you never need heat,
Just unhook the heater hoses under the hood from the heater core, and "loop" them together.
too many is offline   Reply With Quote
Old 06-27-2002, 09:37 AM   #5
hwedding56
hwedding56's Avatar
STOP!! Don't start pulling and plugging. Go to the parts store and ask for a heater control valve. They make a manuel shut off for about 4 bucks. Mine went bad with the vacume control valve. It is nothing but a valve that you just open in the winter and close in the summer takes about 2 minutes. Just cut hose install and close. Hope this helps.
Herbie
PS. Get two hose clamps also. LOL
67-CST Factory PS PB AIR Buckets SWB FLEET 350-700r4
67-SWB Step Plain Jane
350-3 on the tree
68 1-1/2 ton Dump 12' rock Bed soon to have fast68's 292 installed
72 GMC 3/4 ton Crew Cab 402 BBL
400 tranny ( ok I bought it from Crews) Its one ugly long WB long bed 4 door truck!!!!!!!!!
hwedding56 is offline   Reply With Quote
Old 06-27-2002, 11:29 AM   #6
Blue68
Blue68's Avatar
I'm with the last two guys. For a quick fix, just loop the hose from the pump to the intake. I'm doing this for now because my header and a/c units are sitting on a shelf so I can drive it. If you do us the system in the winter ( or in Canada anytime but the summer, note I'm from Texas) and you want heat, get a shutoff valve. This is actually the way the Vintage Air system works, there is a manual valve that is controlled by the hot cold lever.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-27-2002, 07:12 PM   #7
Downtown
Downtown's Avatar
Question
You didn't say if your truck had factory a/c or not. If it has a/c then what is said about the vacuum to open and close the valve is correct. If it doesn't have a/c, then it should have two temperatures. Hot and really hot. Buy the manual shut off valve to keep hot water out of the heater coil.
72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new
66 Chevy Caprice 2 dr
77 Caprice Estate Wagon
New Palestine, IN
Downtown is online now   Reply With Quote
Old 06-27-2002, 09:36 PM   #8
Mountain Man
hwedding56 - Thanks for the idea. I think that the shut off valve is the best way to go. Which hose do I put the valve on to.
If you are looking at the heater core box from the front, is it the upper line or the lower line that I would put the shut off valve into the line.
I do not have a/c.
Thanks in advance.
Full trim
Factory tach dash
A/C dash
Factory tilt
