Old 08-08-2005, 11:18 PM   #1
walker
walker's Avatar
front end swap question
I am just about done with my front end rebuild and have a few minor questions to clear up. I decided to switch to the newer style power steering, had the old ram set up on my '67. The front end is one I bought out of a 71, with disk brakes and manual steering. I bought the new box but I have no power steering pitman arm so I will need to get that. Does the power steering pitman arm fit on the manual steering center link for 71-72? Also, do I need to get a new rag joint, and if so do I just buy one for 71-72 power steering?
Now for the biggie, how do I go about setting the front end up for the drive to the alignment shop. I live about 35 miles from the nearest place and don't want to kill myself, or wear out my tires on the way. I can rig up a couple of levels for the top to bottom of the wheel and make up a sort of out rigger to set toe in/out, but is that enough or is there more I can do?
Thanks, Andy.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-09-2005, 07:33 AM   #2
JimKshortstep4x4
Talking
It sounds like you will be able to get your front end drivable to the alignment shop. Once you have it together, drive it on a short trip to see if it is reasonable to drive. If you are off a little it will wear your tires faster but 35 miles should be ok. If you are putting new tires on it, you may want to install
some old tires so that they take the wear, (have the shop put your new tires on).
Our alignment shop is (7) miles away and we have had to set up lots of front ends for the drive over. Sometimes we are not very close but everything still worked ok. A word of caution on the drag link. It will go on either way so make sure the tie rod ends are on the inside, (between the frame and drag link). I put one together the other way and it does not steer well !
Good luck!
JIm
Old 08-09-2005, 11:46 AM   #3
tomatocity
tomatocity's Avatar
Not to take anything away from our members knowledge base but this weekend I came across Jim of Big Block Chevy Parts and Small Block Chevy Parts. This guy knows his steering, pulleys, etc. He was discussing the different steering box to steering shaft connections with a guy needing a manual box connector. Here is his information.
Jim
eBay: gotpulley
eMail: bigblockjim454@cox.net
480 981-3096 home
602 751-0454 cell
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-09-2005, 07:51 AM   #4
krue
Designated A-hole!
krue's Avatar
Trailer.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-09-2005, 08:14 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The rag joint itself is the same (the rubber biscuit). The metal coupler that it bolts to on the steering box shaft is different though.
The pitman arms are different between power and non power boxes.
The center link is the same, at least on 68 and newer trucks I know, I've never done a 67.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-09-2005, 11:56 AM   #6
Jakes-66-K10
Jakes-66-K10's Avatar
Walker, if you are removing your old PS setup I may be interested in it (depending on price) I have a '67 and a '66 that use the old ram assist style steering.
Jakes-66-K10 is offline   Reply With Quote
Old 08-09-2005, 11:58 AM   #7
tomatocity
tomatocity's Avatar
Andy, I just realized the Jim is in Phoenix.
Old 08-09-2005, 08:11 PM   #8
walker
walker's Avatar
Very cool, thanks for all the help. After I get it installed I take it for a test drive, I guess if it squeals I'll pull it back in the garage and have another go at it till I get it close enough.
BTW, the old ram steering is not worth rebuilding and saving. For the price of rebuilding it you could have a later model gear. You would still need a pump and brackets, as I am reusing mine, and hoses. So you would spend a couple hundred in rebuilding an old style system, or have a newer close ratio steering (that old system is still 6 turns stop to stop).
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 08-10-2005, 08:50 AM   #9
Jakes-66-K10
Actually, the part that I really need is not the ram, but the control valve that the four hoses attached to. Is this part in decent shape?
Old 08-11-2005, 07:52 PM   #10
walker
walker's Avatar
Sorry, the control valve leaks too. They are available at Checker, NAPA, etc. just look them up for a 70's corvette.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
