08-14-2005, 10:51 AM | #1 |
Headlight Keep Burning out. Help
Well I nearly got stranded last night 1 1/2 hours from home with out headlights. The night before the drivers blew out I just did not worry about it. I kinda noticed that there were no lights ahead of me so I said to my girlfriend I dont think my lights are working. She says why dont you pull over and check ?. I knew I better figure out whats wrong. So I pulled over and about 1 minute later a guy who had seen me at a show earlier pulled over just to see what happned. He owns a purple 50's pannel on AIR laying body. It's been featured in Street Trucks it's perfect. Anyways we went to Walmart and they sold everything but round lights. We ended up going back to his shop and he had the old lights from the pannel and one from a hot rod they are building they bolted right in.
On the way home the pass side bulb pops. Any ideas why ? I have a original headlight switch and a new cheep high low beam switch. Could either of these parts be a problem ? All the wiring is setup right. Thanks for any help.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-14-2005, 11:01 AM | #2 |
Franko72
what do you mean bulb popped. went out or popped(busted).Put a meter on your charging system.see how high your system is charging. could be a faulty regulator. Is the battery boiling over thru the caps?check the dimmer switch that you replaced to be sure the connections or wires are not grounding out to the floorboard.check the connections for tightness.get some die electric spray and spray inside of the head light socket connectors.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
08-14-2005, 11:06 AM | #3 |
The bulbs turn BLACK. I will check the voltage at the headlight.
08-14-2005, 12:02 PM | #4 |
take apart ground wires make shiney metal to shineymetal grounds with a bit of dielectric grease for good measure
08-14-2005, 07:03 PM | #5 |
Regulator. Mine did the same thing. Blew a few bulbs before I figured it out.
Nice truck by the way. Darren
67- 72 Parts collecter |
08-14-2005, 08:50 PM | #6 |
I checked the voltage in my 67 it's a internal reg alt. I got 14.6 inmy 84 I have 14.4. Could it be peeking higher going down the road ?
08-15-2005, 02:46 AM | #7 |
Black 72 Chevy
72 Mario voltage regulator is going bad and its spiking causing to burn out your head lights.
08-15-2005, 06:24 PM | #8 |
Thanks for the bad and good news. The bad is I am broke the good Is all I have to do is carry a extra bulb till I get it fixed. Which will be very soon.
08-15-2005, 06:54 PM | #9 |
71 Cheyenne SWB Fleetside
hey, the more you drive that truck the more broke you'll be too. gas is 99.9 cents a litre here in sarnia.
joel
08-15-2005, 10:15 PM | #10 |
I know it's 114.? for 94 she likes to burn. Oh well
