08-15-2005, 09:38 PM | #1 |
FUEL CELL GURU
Ordered new wheels....
today for the 2WD Blazer project. I ordered 4-20" x 8.5" Eagle 025 with 4-Goodyear Eagle GTII 275/45-20, with valve stems, lugs and locks for $1488 shipped to my door. Not a bad price IMO. www.bigjimsrims.com
Later, Mark |
08-15-2005, 11:09 PM | #2 |
That is going to be a heck of a Blazer Mark. When do you plan to swap the body onto the frame?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-16-2005, 07:24 AM | #3 |
FUEL CELL GURU
I am hoping I can start the disassembly this weekend. There are a couple of firewall issues I will need to deal with before I take the tub off the 4WD chassis. I need to go ahead and smooth the fiewall and fix a couple of minor rust spots. I am going to go ahead and bedliner the firewall for additional insulation and noise dampening. I will be spraying a light coat, not the 3/8-1/2" typically found in a bed. I still have to order the TBI wiring harness and gather up a few sensors. Hopefully I can have most of this done by November. Business first, then play. I'd like to hit the guy that coined that phrase.... Later, Mark
08-16-2005, 08:34 AM | #4 |
GO VOLS!
Nice wheels, those will look great on your blazer. Now hurry up and get them mounted so we can see some progress pics
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
08-16-2005, 11:26 AM | #5 |
Gonna be some serious meats! Good looking rims.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-16-2005, 12:39 PM | #6 |
Can anyone tell me the height of these wheels and tires?
08-16-2005, 01:01 PM | #7 | |
Tire sizing info to help you figure out what I am doing: 275/45-20 275 is the width of the tread in millimeters. 45 is the aspect ratio of the side wall, so in this case 45% of 275mm 20 is the wheel size (obviously) Sidewall: 275mm x 45% = 123.75mm convert to inches = 4.87" So you have 20" plus two sidewalls of 4.87" = 29.74" That seems taller than I thought it would be, so I think there is something I am missing. Anyone help out?
08-16-2005, 12:58 PM | #8 |
doing the math, the tires should be about 29.7 inches tall.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
08-16-2005, 01:01 PM | #9 | |
08-16-2005, 01:04 PM | #10 |
seems a little tall to me too, but it has to be right if we both got the same answer... (or we're both just as dumb )
08-16-2005, 02:53 PM | #11 |
Thanks for the info. Now I have to do some measurments to see if those will fit under my Jimmy. I do like the way tall rims look on the 2WD 's.
08-16-2005, 05:08 PM | #12 |
The LuvShack Garage
08-16-2005, 09:24 PM | #13 |
FUEL CELL GURU
A hair over 29" is right. I had the exact same size wheel and tire on the 68 with no problems EXCEPT this time I will run a 1/4-1/2" spacer on the rear. They very seldom rubbed the inner fender well but occasionally, they did. Other than that, they should fit. Later, Mark
08-16-2005, 09:58 PM | #14 |
That's a nice looking truck, Mark. Do you still have it? If so, you should have the beginnings of a nice fleet when the Blazer is done.
08-16-2005, 10:31 PM | #15 |
PROJECT 7DEUCE
Those are some pretty clean looking wheel's.... Can't wait to see them on..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-16-2005, 10:37 PM | #16 |
nice pick, they're going to look sweet mounted on the 2wd.
08-16-2005, 10:58 PM | #17 |
FUEL CELL GURU
No, the truck is now in the possesion of another board member in Houston. I haven't heard anything from him lately. I need to give him a call and check in and make sure ol' peachy is treating him right. My wife asked me the other day if I missed it and I said nah, there's always another behind in line to be fixed up. Thanks for all the comments on the wheels. I want to get this project over with so I can start my next LOOONNNNGGGG term project.......the 68 Camaro. Later, Mark
08-20-2005, 08:11 PM | #18 |
FUEL CELL GURU
Well, here they are, mounted and installed. I think I like them. Later, Mark
09-05-2005, 10:04 AM | #19 |
FUEL CELL GURU
Just a reminder, after putting the body on, I only have 1/4" clearance between the tire and the inner fender well. These are the exact same size wheel,tire and backspacing I had on my 68. These wheels will still work with the addition of these...http://www.ezaccessory.com/.sc/ms/dd...%205%26quot%3B
I will be ordering the 1 1/4" spacer. Later, Mark |
