Old 08-16-2005, 07:09 PM   #1
newin72
some serpentine setup questions
ok I really don't know where to start... but here are a few questions
Assuming I get a setup off of a 4.3 V6 like has been recommended:
1. will power steering pump cables mount right up to my existing steering box? (72 suburban with factory power steering)
2. will I have to custom fabricate AC hoses to mount to factory installed front/rear air.
3. will I have to do custom wiring for the Alternator?
4. I need a different water pump also?
thanks!!
newin72 is offline   Reply With Quote
Old 08-17-2005, 12:12 AM   #2
Jetmech727
read this it might help
http://67-72chevytrucks.com/vboard/...d.php3?t=139517
"When cows laugh, does milk come out of their nose?"
Jetmech727 is offline   Reply With Quote
Old 08-17-2005, 12:21 AM   #3
newin72
hmmm... wouldn't let me open it.
Not Found
The requested document was not found on this server.
Old 08-17-2005, 07:53 AM   #4
neonlarry
neonlarry's Avatar
No
Yes
Yes
Yes
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-17-2005, 10:10 PM   #5
newin72
thanks.
anybody else have more input or suggestions?
jetmech... any more suggestions on how to open that link?
Old 08-17-2005, 10:28 PM   #6
Russell
Professional Grade
Russell's Avatar
Do yourself a favour and don't get an 85 setup They have one big bracket that is prone to cracking if all of the factory brace bars are not installed (tough to fab them to work on your carb intake)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-18-2005, 09:30 AM   #7
64fleetside
If you swap the fitting in the rear of the PS pump you can use stock hoses, like Russell said avoid earlier & van setups w/one piece metal brkt, get the 2 piece aluminum style, you need a reverse rotation water pump. Brian
64fleetside is offline   Reply With Quote
