08-16-2005, 07:17 PM | #1 |
Hei?????
I have a 1969 C10 with the original 350 engine in it and it has A/C. I want to put a HEI dist. in it. What do I need to look for?.....vac, no computer, one wire???????????/
thanks |
08-16-2005, 07:24 PM | #2 |
I have one on my 396 (it was formerly on a 350) it has vac advance and two male spades on the right (Ign and Tach). Just be aware your spark plug wires are not compatable from the stock dist to the HEI. I have a spare HEI laying around. If your interested PM.
08-16-2005, 07:29 PM | #3 |
Thanks for the info on plug wires.........I was not aware...........and to think I just bought new.
How much for the HEI? Will have to ship to east TN |
08-16-2005, 07:29 PM | #4 |
its all about the +6 inches
Lots written about this in the FAQ
08-16-2005, 07:36 PM | #5 |
thanks Longhorn
08-16-2005, 09:16 PM | #6 |
lose the original resistor wire feeding the points dizzy....
run a new wire from the fuse box to run the hei..... the old wire only feeds about 10 volts......... you need full 12 volts for the hei dizzy..... |
08-18-2005, 08:37 AM | #7 |
...looking for the part number for the GM pigtail for the HEI distributor??? Anyone know? Napa #? I'll keep looking.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
08-18-2005, 08:44 AM | #8 |
08-18-2005, 10:30 AM | #9 |
More info:
"Check NAPA/Belden: Terminal - 784491 Plastic - 784531 I don't believe this plastic has a latch. Just pinch the sides of the terminal so it fits real tight and you won't need a latch. For "originality", I think you need a Packard Electric 8911379. One of the Chevelle wiring builders should be able to supply or go the junkyard route. To remove plastic from terminal insert a small screwdriver into the small notch on the business end of the plastic, then pull on the wire." and "GM sells a connector replacement pack that includes the tach and power lead for an HEI distributor. The AC Delco part number is 12167658." Just thought I would repost this info for someone else searching for the same stuff.
08-18-2005, 11:08 AM | #10 |
Hei
I just did this upgrade and followed the directions in the FAQ's area. I went to the junk yard and pulled a HEI out of a '78 Blazer. Installed it in about an hour and it runs great!
