08-17-2005, 02:33 PM | #1 |
How to replace door hinge spring?
Can anyone tell me how to replace the door hinge spring (keeps door open) on a 1976 C10 door?
Any help is appreciated. Thanks. |
08-17-2005, 03:31 PM | #2 |
Insert Witty Text Here
I have a broken spring as well on my driver's door. I have seen discussion in the past where one person said he was able to install a spring with the door on the truck using a long screwdriver. I have not been able to do it with the hinge in place. Everyone else I have seen discuss it said the spring must be installed with the hinge off the truck.
I hope someone has a nice solution. Slonaker |
08-18-2005, 09:53 PM | #3 |
I just hold up the door (I have a door lift but you can improvise) take off the door and hinge and replace it. it doesn't take very long. I've never been able to get it in w/o removing it.
08-18-2005, 10:15 PM | #4 |
ureckmefixit2@cox.net
I have, but its hard to put in words. Put in spring, use big bent screw driver to twist spring and hammer in to place. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
08-19-2005, 02:31 AM | #5 |
OutOfMyMind & I'llNeverKnowWhy
I changed just the S shaped spring with the door still on the truck. Open the door all the way and put the S spring into the top slot first, with it slid as far down as it will go. Then make sure its lined up in the middle slot in the hinge. Then, using the door, start to close it slightly. You will see where the stock "little wheels" will push on the bottom part of the S spring. Close the door enough to where the S spring is lined up with the bottom slot. Use a small hammer and lightly tap it till it seats in the bottom slot.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
11-06-2017, 04:52 PM | #6 | |
Re: How to replace door hinge spring?
79 Chevy 2wd BIG10 350 TH400 |
08-19-2005, 09:06 AM | #7 |
Thanks to all, I'll have to give this a try.
08-19-2005, 10:06 PM | #8 |
Genuine Chevrolet
They also make a tool that compreses the spring. Works really slick.
George 82 Silverado LWB 4x4 350 SM465 NP208 77 Chevrolet Blazer Chalet 400 TH350 NP203 |
11-07-2017, 09:28 AM | #9 |
I have to try this..My passenger side spring broke about 4 years ago. The door hits my wife all the time because she still expects it to stay open.
11-24-2017, 11:40 PM | #10 |
Forget the spring. Time to change wives, if'n after four years she ain't figgered out the door taint gonna stay open!
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
11-07-2017, 02:00 PM | #11 |
i dont think i ever did one on a full size but for the s10s they sell a tool. but before i used the tool i used to put the springs in a vise but left a little bit sticking out so i could run some thin wire through ti to keep it compressed, stuck the spring in and cut the wire. thankfully i never lost a eye doing it that way
11-17-2017, 04:50 AM | #12 |
Going to try this tomorrow. Thanks
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
11-17-2017, 09:10 AM | #13 |
11-18-2017, 04:17 AM | #14 |
I did it with just a flatbar.
Worked like a champ.
