Old 08-17-2005, 06:01 PM   #1
KAILUAZ
King of Rust
KAILUAZ's Avatar
Question Theft question
Ok, so my PO changed from a manual trans to auto and installed a new steering column.
Question is, should the steering wheel and trans shifter lock when the ignition is turned off??
As it is right now you can jump in the truck and put it in neutral and steer it off to criminal land.
Any thoughts/help?? 1970 GMC w/TH400.
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 08-17-2005, 06:05 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Stock auto column does NOT lock.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-17-2005, 06:11 PM   #3
pjmoreland
pjmoreland's Avatar
I put a club on my steering wheel when I leave it in places like airport parking lots.
pjmoreland is offline   Reply With Quote
Old 08-17-2005, 06:26 PM   #4
matthufham
clubs can be taken off by a pro in about 2 seconds. my auto column doesn't lock, and my floorshifter has no neutral safety switch so i can shift without a key or braking.
matthufham is offline   Reply With Quote
Old 08-17-2005, 06:48 PM   #5
KAILUAZ
King of Rust
KAILUAZ's Avatar
Guess I'll have to setup a steering cable lock like the HMMWV's I drove in the Army. Thanks for the quick responses!
My Pics
Old 08-18-2005, 08:21 AM   #6
junkyardjohn
junkyardjohn's Avatar
I WOULD LIKE TO SEE ANYONE REMOVE A CLUB IN TWO SECONDS. BETWEEN THE CLUB & A KILL SWITCH, IT'LL SLOW THE THEIVING B@STARDS DOWN LONG ENOUGH THAT I CAN DEAL WITH THIS PROBLEM ON A PERSONAL LEVEL. AS FAR AS NOT BEING ABLE TO TOW A LOWERED TRUCK?? WELL THAT SOUNDS LIKE A CHALLENGE TO ME. NO ONE PAYS ANY ATTENTION TO A WREAKER. I'VE TOWED CARS WITH THE ALARM BLARING, & EVEN HAD A COP STOP TRAFFIC FOR ME. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-18-2005, 08:59 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by junkyardjohn
I WOULD LIKE TO SEE ANYONE REMOVE A CLUB IN TWO SECONDS.....
Ok, picture this. I break in to your truck and pull out a midsize pair of bolt cutters. I make one cut on the steering wheel rim push it down and slide the club off and throw it on the ground. How long did that take?????
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-18-2005, 09:55 AM   #8
fade94
fade94's Avatar
I had a friend that put a small switch behind the dash, under the ignition switch. It was wired so that unless it was engaged, the fuel pump, starter and ignition system would not work. He had it set up so that a magnet on his key ring stuck to the dash engaging the switch and allowing the car (67 Camaro) to start. I thought it was pretty slick.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-18-2005, 02:03 PM   #9
JoetheMobster
Listening since '86
JoetheMobster's Avatar
LMFAO!! Picturing you driving down the road with the alarm blaring. Sadly, you are very correct on no one paying any attention to alarms any more. I for one won't give them the time of day, well not any more.
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 08-19-2005, 05:11 AM   #10
jlmtrout
Just my 2 cents worth, but ugly trucks don't get stolen. I like the Grant system and plan to install one in the very near future (after I install my tilt column, when the weather cools down some). Good luck and keep on truckin'...............Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 08-19-2005, 07:28 AM   #11
Mongo
YES_____NO
Mongo's Avatar
They do if you have a $29.99 Shchucks Stereo in them. when I had the luv (it was a POS) it got taken and when it was found the radio was missing.... go figure. Guess it was worth more than the truck Oh and funny thing is when the cops found it, it had more gas than when it was taken
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 08-18-2005, 01:56 PM   #12
JoetheMobster
Listening since '86
clubs can be taken off by a pro in about 2 seconds...
It can be taken off by anyone with a hacksaw (or bolt cutters as mentioned by n2trux) in 2 seconds! Cut the steering wheel, throw the club out the window where the vehicle sat, and call it a day!
Old 08-19-2005, 12:13 AM   #13
junkyardjohn
TWO SECONDS IS NOT VERY LONG. I DON'T BELIEVE YOU OR ANYONE ELSE CAN GET ONE OFF IN TWO SECONDS. NEXT YOU'LL BE TELLING ME THAT YOU CAN BENCHPRESS 600 LBS. JOHN
(BESIDES.. MOST CAR THEIVES DON'T CARRY AROUND A HACK SAW OR BOLT CUTTERS)
junkyardjohn
DON'T RENT U-HAUL
Old 08-19-2005, 02:36 AM   #14
KAILUAZ
King of Rust
KAILUAZ's Avatar
Anyone ever use one of those brake locks they sold in the JC Whitney catalog?
My Pics
Old 08-17-2005, 06:46 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep...pretty dern easy to steal.
Old 08-17-2005, 07:27 PM   #16
pjmoreland
pjmoreland's Avatar
If you're dealing with a professional thief, there really isn't anything you can do to stop him, right? Of course he will probably be looking for something that is worth a little more than my beat up old truck. Now some punk kid who knows how to hotwire an old vehicle and wants to take it for a joyride might consider it. Just my opinion.
Old 08-17-2005, 08:22 PM   #17
clean71
clean71's Avatar
As mentioned in a similar thread, may want to go with the removeable steering wheel.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 08-17-2005, 08:38 PM   #18
KAILUAZ
King of Rust
KAILUAZ's Avatar
Too bad the search doesnt work, any idea where that thread is?
My Pics
Old 08-17-2005, 08:54 PM   #19
Longhorn Man
You don't even need to know how to hotwire... it's quicker to plug in an ignition switch that you carry with you.
Old 08-17-2005, 09:00 PM   #20
KAILUAZ
King of Rust
KAILUAZ's Avatar
Yeah, thats a good thought,,,, to bad my ignition is shot and my house key will work. YIKES!!
My Pics
Old 08-18-2005, 05:36 PM   #21
GMC AMI
GMC AMI's Avatar
Talking
How many crooks now a days have one of these in their back pockets?
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-19-2005, 07:24 AM   #22
Mongo
YES_____NO
Mongo's Avatar
I just happen the carry around two of them at all times.
Old 08-17-2005, 10:28 PM   #23
shifty
Questionable
shifty's Avatar
Removeable steering wheel? Any reputable theif will scope out the vehicle first and bring the parts they need the next visit. That may include a steering wheel.
My advice is to lower it so much that it's laying frame and it can't be towed, then make the pump inoperable.
In addition to that, install an alarm, fuel kill and starter kill. Then add lojack. If anyone can get past all that crap, they deserve the damned truck.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-18-2005, 12:02 AM   #24
70short/step
70short/step's Avatar
I have the grant steering wheel lock that removes the steering wheel and places a guard over where the steering wheel mounts. It uses a key to lock and unlock. It only takes a second to do this.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 08-18-2005, 02:25 AM   #25
Americanrider
Install a floor starter out a 55 or 56.... That way you know the theif will have to be at least 45 yrs old to figure it out
Americanrider is offline   Reply With Quote
