Old 08-20-2005, 10:52 AM   #1
hobbz
hobbz's Avatar
help with ball joints
i am in the process on lowering my 78 c10 and i am trying to get the front lower ball joint loose and i can't...
i have everything else loose and have been hitting the crap out of the side of the spindle by the ball joint for at least 30 minutes and still nothing...
i also tried one of the traditional fork ball joint seperators and still nothing...
does anyone have any other ideas??
could i take a torch to the spindle for a couple of minutes and maybe that help loosen it???
thanks for the help
chris
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 08-20-2005, 11:26 AM   #2
Joe67
67 is sold
take off the control arm and have it pressed out at your local auto parts store. Have them press in the new one while they're at it
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-20-2005, 11:59 AM   #3
hobbz
hobbz's Avatar
well i got it...whoever said you don't have to take the tie rod end loose was wrong... i took the tie rod loos and swung the spindle all the way to the bad then took the pickle fork and put it in from the front and beat it(like m jackson) and finally it popped loose... i can't believe the bfh didn't work though...
Hobbz-Garage
Old 08-20-2005, 02:40 PM   #4
dennislbrooks
dennislbrooks's Avatar
Besides the machine shop or using an expanding press bolt--I have found that if you wedge the fork in tight, reverse the castilated nut and use a punch to smach the ball joint stud. I agree remove the tie rod end first. I use never-seize on the new studs to allow easier removal.
dennislbrooks is offline   Reply With Quote
