Old 08-20-2005, 02:44 PM   #1
dennislbrooks
dennislbrooks's Avatar
87 spindles
Are the 87 1/2 ton front spindles the same for the HD and LD brakes? If they are then I am guessing that you need to only make sure the rotor and caliper combos match.
dennislbrooks is offline   Reply With Quote
Old 08-20-2005, 03:06 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Spindles for the 1" vs. 1 1/4" rotors are different and are not interchangeable. But, you can swap spindles, rotors and calipers as a whole between the two.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 08-20-2005, 04:01 PM   #3
dennislbrooks
Ok--do the LD (1 1/4" bore) spindles take an A6 inner bearing and the HD an A5 (1 3/8" bore)? thanks
Old 08-21-2005, 12:37 AM   #4
boxrodz
boxrodz's Avatar
I'm not sure on the bore size, but I believe you are correct with regard to the inner bearings.
boxRODz
Old 08-20-2005, 06:31 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
A good rule of thumb is that you have HD brakes if you can fit a finger in the holes on the edge of the rotor. The holes on the regular brake option are smaller.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
