Need carb guru
My quadrajet has a problem.
I can get in and crank and crank and no fire. if I take alittle bit of gas and dump it down the carb she fires right up and ------stays running!!!!!!! and runs fine after that butterfly is closed when trying to start it so the choke is working. Filter is new and so is the filter in the line before the carb. how about some suggestions. Far as I know it is a rebuilt carb.
Core plugs on the bottom are leaking fuel, common prob on q-jets. Pull carb, turn over, pull baseplate,epoxy all core plugs, reassemble. Brian
Is the accelerator pump shooting a good stream of gas when you pump it?
Jim |
Fuel filter in backwards....you might be surprised.
I vote with 64, core plugs. Just pump the accelerator and see if fuel is coming out. No gas outta the squirters is a good indication.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Jim K is the winner!!
I pulled the carb and checked the accelerator pump and the rubber was off the bottom end. swapped pump rods and now she starts!! Thanks for all the suggestions and will have to check to see if the core plugs are leaking in the near future. At least it starts and runs now. Thanks again Shannon
