08-24-2005, 09:18 PM | #1 |
i love summertime
any diff between lwb 4x4 truck frame and burb frame?
like the title says...will a burb sit on a 4x4 chassis ? im not even sure the wheel base is correct or not? thanks in advance
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
08-24-2005, 10:45 PM | #2 |
The frames are shaped differently, and the chassis's are different length. Someone should have the exact measurements.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-24-2005, 11:28 PM | #3 |
Pretty much the 4x4 frame will accept a burb body. The differences are that you need to use the rear cab support from the burb onto the 4x4 truck frame, and the three or so brackets off the top of a burb frame to mount the burbs body as the truck 4x4 frame would have brackets to mount a pickupbox which will have to be removed..there riveted on.
Look at GMC Pauls web site home page the 1970 GMC Blue 3/4 4x4 GMC was made using a 70 Chev suburban 3/4 4x4 frame I owned..friend built that truck in 3 weeks...he was good at that type stuff. Even if the burb was 2wd to start with use the same brackets I mentioned on the 4x4 frame....just gotta watch the height that the rear cab support is mounted at. I got a 4x4 burb here if you need a measurement or few or pics when your at it. The wheel bases are the same. The truck frame will be shorter at the back end as it was cut for a truck box..maybe 6 -8 inches were cut off..you could cut the back of the burbs frame to get the added lenght welded on. Not a big deal if your going for it.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
08-24-2005, 11:39 PM | #4 |
burb
The frame rails are the same. The body/bed mounts are different. My plow truck is a LWB fleetside on a '71 burb frame. I had to add rear cab mounts and the front 2 box mounts on each side.................Z
08-24-2005, 11:50 PM | #5 |
i love summertime
thanks guys, great info
08-25-2005, 05:15 AM | #6 |
I recently noticed that the first exhaust hanger bracket back from the engine is farther back on my '72 4x4 pickup than on my '71 4x4 burbs. The burbs have it near the xfer case; the pickup has it nearer the rear springs.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
