Old 08-25-2005, 01:05 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Need Help w/ Door Locks
Ok, here's the problem. I can lock my doors when the doors are open but when I shut the doors, they do not stay locked. I think the problem is the same if I lock the doors from the inside. All I have to do is push the button on the door handle and they pop right open. Anybody have any advice other than replacing the latch assemblies at $50 a pop?
Oh, and the door lock cylinders are frozen too.
Ole Blue 68 is offline   Reply With Quote
Old 08-25-2005, 01:10 PM   #2
StingRay
StingRay's Avatar
It's normal. The only way to lock a door on a 67-72 is with the key from the outside or popping the button down on the inside and then staying inside. There is no way to lock it and then close the door. Add power remote locks if you really can't stand it.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 08-25-2005, 01:29 PM   #3
72BLAZERDUDE
72BLAZERDUDE's Avatar
Does work great for making sure you cant lock your keys in the truck. Hated that when my wife did that with the car.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-25-2005, 01:58 PM   #4
Ole Blue 68
So if I replace the frozen lock cylinders, I should be good to go?
Old 08-25-2005, 02:47 PM   #5
355
355's Avatar
You should be good to go. Why not squirt some wd-40 or kroil into the locks and work them free, really shouldn't be that hard or am I not understanding something.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 08-25-2005, 05:06 PM   #6
Ole Blue 68
I tried to loosen them up with some WD-40 but they're not budging and I'm afraid if I put too much more pressure on it, I'll bust the key.
I was thinking about trying some liquid wrench and letting it set for a while. And if that don't work them I'm gonna have to go with new lock cylinders I think.
Old 08-25-2005, 05:12 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
So you tried to lock the doors...even though you can't unlock them with the key?
I would try pulling the door panel off, and soak all the linkages and the back side of the lock cylinder with PB Blaster. This stuff is way better than WD40 could dream of being....Liquid wrench is ok...but PB is still way better.
Old 08-25-2005, 08:31 PM   #8
71swb4x4
71swb4x4's Avatar
Can you lock them with the door open? If you can then try pushing on the door when you lock it. It may just need a little nudge to take the pressure off the mechanism.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-25-2005, 09:20 PM   #9
chops333
i second the pb best stuff ive ever used on rusty fasteners sprayed 36 year old rear bumper bolts let them set 30 minutes broke them loose with wrench then turned them off by hand great stuff
chops333 is offline   Reply With Quote
Old 08-25-2005, 09:34 PM   #10
mrwilmoth
how about installing power locks? anyone got a faq for that?
mrwilmoth is offline   Reply With Quote
