08-26-2005, 10:46 AM | #1 |
1988-1998 bench install.
I installed my 98 bench back in mid july. Now that I have got around 3000 miles on the truck I find that the seat might need to be tilted back. This may sound kinda dumb but there is no thigh support I bolted it flat to the floor. Anyone else out there mount theres that way ? How does it feel to you ? I am thinking of pie cutting the brackets so that it tilts back more. I couls put a spacer under the front but the seat sits hight enough as it is.
Later,
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-26-2005, 02:58 PM | #2 |
I'm about to do the same seat, just had to take it apart and paint the steel mounting brackets. I'll let you know how I make out.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
08-26-2005, 05:57 PM | #3 |
I have a 92 bench and I found mine just the opposite I had to shim the rear with a couple of nylon furniture wedges with a hole drilled for the bolt and put them between the bracket and the floor. Raises the rear up about 3/16-1/4".
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
