Old 08-29-2005, 09:23 PM   #1
red86chevy
Vacuum Secondary spring
I have a mild 350 with sportsman II heads (64cc) and a comp 270h cam, and a 3.73 gear. It has a holley 600 vacuum secondary carb on top of it. A while back I installed the white (lightest) spring.(it had the black one in it...heaviest) But like for ex if I pull it down into 1st and tach it up to around 35000 and hit it its like it has a pretty good hesitation until it really gets turning. It doesn't really do it off Idle to WOT just when I do it this way. Do you think the spring is too light. I don't remember how it reacted with the heavy spring in it. What do you guys think.
Also I remember a check valve of somesort in there somewhere. Where is it? and will it fall out when I take off the secondary diaphram housing?
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
Old 08-30-2005, 09:17 AM   #2
86 GMG
yes the little ball will fall out if not care full holley has a quick change that allows you to remove a cap on top and change spring its a lot easier and faster i think mine that i bought was 15.00 at a parts house
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
